Smokey Start Up
Posted: Mon Oct 01, 2012 2:49 pm
by Chris999
Hi there,
I've got a 2008 Avant with 22k miles. I was away last week and when I started the car yesterday I was greeted with a cloud of white smoke (it was smoke and not steam). Not noticed it before any ideas?
Many thanks
Re: Smokey Start Up
Posted: Mon Oct 01, 2012 4:52 pm
by ollys
It's normal
Re: Smokey Start Up
Posted: Mon Oct 01, 2012 6:28 pm
by RS6chris!
Yep...my RS4 was the same..more so if its been used for a quick start and move on the drive or been sat for a week or so.
My RS6 does same.
Oh and
FON
Re: Smokey Start Up
Posted: Mon Oct 01, 2012 7:49 pm
by Chris999
Thanks, that was the answer I was hoping for
Re: Smokey Start Up
Posted: Mon Oct 01, 2012 8:54 pm
by perthwaRS6
Apparently shows that your secondary air pump is doing its job warming up the catalysts and burning off the rich start up fuel mixture. Should only last for a couple of minutes till revs drop back from 1200 rpm to normal idle around 700rpm.
Re: Smokey Start Up
Posted: Mon Oct 01, 2012 11:51 pm
by Golfather
Theres a technical bulletin for right hand side oil return pipe.
Check it out if it needs doing.
Re: Smokey Start Up
Posted: Tue Oct 02, 2012 12:23 pm
by perthwaRS6
Hi Golfather,
Thank you for your advice. Can you provide the number of the TPI.
Any advice appreciated.
regards,
john
Re: Smokey Start Up
Posted: Tue Oct 02, 2012 4:03 pm
by Golfather
TPI 2022183/1
Oil spillage vessel fitted to rectify smoke on startup from right hand side exhaust.
Re: Smokey Start Up
Posted: Tue Oct 02, 2012 5:58 pm
by RS6chris!
Will this be done to any car that needs it? Or does it have to be asked for?
Re: Smokey Start Up
Posted: Tue Oct 09, 2012 12:39 pm
by luffenham1
I have no smoky start up but if I boot it, blue smoke comes out the back. My rs4 did this so I don't know if I need to be worried about this. The rs4 was a right smoker, at least 30 a day.
