Page 1 of 3
Gloss black air intakes below headlights.
Posted: Sun Jun 10, 2012 7:37 pm
by RS6chris!
AS title guys?
The "747" fans as theyve been called on here! below the headlights are full of crud..leaves...crap etc etc...i need to clean the intakes out ASAP..But my fat fingers cant get bewteen the louvres....do the black plastic surronds just "clip" out similar to the B7 RS4 ones or is it a bumper off job?
Used to clean my RS4 ones out regular to prevent corrosion of oil cooler pipes....dont know what type of pipes etc are behind the C6 grilles but id like to clean crap out from fan intakes and in the long term prevent any corrsion issues?
Any info greatly appreciated?.....
Chris.
Re: Gloss black air intakes below headlights.
Posted: Sun Jun 10, 2012 8:01 pm
by HYFR
YES ! mine too !
so I have the exact same question, just didnt get round to posting it .... good work Chris
anyone ?
Posted: Sun Jun 10, 2012 9:12 pm
by andy
Damn, now that's another thing I need to go out and check
Posted: Sun Jun 10, 2012 9:18 pm
by RS6chris!
Them intakes will suck up small children!!!!
Posted: Sun Jun 10, 2012 9:44 pm
by andy
And once you get them out, I wonder if someone makes a carbon version??
Step away from the search engine
Posted: Mon Jun 11, 2012 7:02 am
by gdavison
Luckily I can just about get my hand in the middle gap to clean them out .. Good idea to clean them on a regular basis I have always checked mine as the Boxster has a similar design and its a well known issue on them that the soggy leaves gather and rot the AC radiators
Posted: Mon Jun 11, 2012 10:00 pm
by speedfr38ky
Yes they do clip out but are inverted clips. A real pain in the arse,to unclip. Pushing them back in is easy, taking them out is a ball ache.
Posted: Mon Jun 11, 2012 10:14 pm
by andy
Checked mine tonight and they are clear, for now. Good call on keeping an eye on them
Posted: Tue Jun 12, 2012 2:53 pm
by RS6chris!
speedfr38ky wrote:Yes they do clip out but are inverted clips. A real pain in the arse,to unclip. Pushing them back in is easy, taking them out is a ball ache.
Any tips for removing "technique"..?
Posted: Thu Jun 14, 2012 7:46 pm
by RS6chris!
ANYONE!!!
My cack hands have broke two off the clips on the O/S one trying to get it off.
Someone must have a method......hoiw would an Audi mechanic or bodyshop remove them?,,,surely not a bumper off job?
Posted: Thu Jun 14, 2012 9:23 pm
by catfood12
They'd do it more carefully than you fellow, for sure !.... or maybe not if you took it to Poole Audi. They'd probably put a ding in the door too.
Posted: Fri Jun 15, 2012 7:49 pm
by speedfr38ky
Use a small flat head phillips screwdriver!!! Be gentle and.tape the head to stop scratching.
Posted: Fri Jun 15, 2012 8:06 pm
by RS6chris!
speedfr38ky wrote:Use a small flat head phillips screwdriver!!! Be gentle and.tape the head to stop scratching.
I assume i work my way along the edges?...anywhere specfic??
Posted: Fri Jun 15, 2012 8:16 pm
by gdavison
hate to be technically accurate
Phillips is a cross head
I'll get my coat
Posted: Fri Jun 15, 2012 8:27 pm
by doodlebug
Is it a left handed, flat head Phillips?
