Vagcom/VCDS or OBDeleven
Posted: Mon Oct 31, 2022 2:50 pm
by Duke Thrust
Hi all,
What the view on Vagcom/VCDS versus OBDeleven?
I need to do a couple of reset functions, DTC memory of ECU Number 2 and reset of drivers seat memory.
Would welcome people's opinions.
Thanks!
Re: Vagcom/VCDS or OBDeleven
Posted: Tue Nov 01, 2022 3:25 pm
by Charmie86
hi
i have used both, Vagcom is really good if your gonna get indepth, its easier to use than obdeleven, i have obdeleven to check fault codes etcs, can do a lot if not everything that Vagcom can do just a little harder to navigate. whats up with your seat, i lost all adaptions for my drivers seat when i was having battery problems. i moved the seat to the end of each axis eg forward/back u/down and that sorted it. it need to relearn its limits
Paul
Posted: Wed Nov 02, 2022 4:20 pm
by Duke Thrust
Thanks, good info.
The memory function doesn't work on the drivers side (works fine on the passenger side). From what I've read the seat needs a reset.
(I've tried the all the way forwards, up, back, down thing - no joy)
Posted: Wed Nov 02, 2022 5:34 pm
by stuartbarriskell
I'm also interested in buying a "reader".. the one that I've been recommended is under 40 quid, Where's best to buy the Vagcom from
Stu
Sent from my SM-G998B using Tapatalk
Posted: Thu Nov 03, 2022 1:26 pm
by Charmie86
i know this is silly question but you havent got the memory seats switched off on the buttons cause my wife has a habbit of knocking the on/off button
Posted: Thu Nov 03, 2022 4:50 pm
by Duke Thrust
I excitedly thought that might be the problem and rushed out in the rain to check, but sadly no.
