Sunday,29,May,2022,15:30:46:00001
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x86
VCDS Version:
https://protect-eu.mimecast.com/s/m6a1C ... n=17.8.0.1
Data version: 20170721 DS276.2
https://protect-eu.mimecast.com/s/TITcC ... s-tech.com
VIN: WUAZZZ4F28N902330 License Plate: CS54LSS
Mileage: 223260km-138727mi Repair Order:
Chassis Type: 4F (4L0)
Scan: 01 02 03 05 06 07 08 09 0E 0F 11 31 14 15 16 17 19 1E 36 37
42 46 47 4F 52 53 55 56 57 61 62 65 6C 6D 72 76 77
VIN: WUAZZZ4F28N902330 Mileage: 223260km-138727miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
05-Acc/Start Auth. -- Status: OK 0000
06-Seat Mem. Pass -- Status: OK 0000
07-Control Head -- Status: Malfunction 0010
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
0E-Media Player 1 -- Status: OK 0000
0F-Digital Radio -- Status: OK 0000
11-Engine II -- Status: Malfunction 0010
31-Engine other -- Status: Malfunction 0010
14-Susp. Elect. -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
1E-Media Player 2 -- Status: OK 0000
36-Seat Mem. Drvr -- Status: OK 0000
37-Navigation -- Status: OK 0000
42-Door Elect, Driver -- Status: Malfunction 0010
46-Central Conv. -- Status: OK 0000
47-Sound System -- Status: Malfunction 0010
4F-Centr. Electr. II -- Status: OK 0000
52-Door Elect, Pass. -- Status: Malfunction 0010
53-Parking Brake -- Status: OK 0000
55-Headlight Range -- Status: OK 0000
56-Radio -- Status: OK 0000
57-TV Tuner -- Status: OK 0000
61-Battery Regul. -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
65-Tire Pressure -- Status: Malfunction 0010
6C-Back-up Cam. -- Status: OK 0000
6D-Trunk Elect. -- Status: Malfunction 0010
72-Door, Rear Right -- Status: OK 0000
76-Park Assist -- Status: OK 0000
77-Telephone -- Status: OK 0000
Address 01: Engine (BUH) Labels:. 07L-910-552-BUH1.clb
Part No SW: 4F1 910 552 D HW: 4F1 907 552 A
Component: 5.0L V10/4V TFSI ª0030
Revision: F1H05--- Serial number:
Coding: 010D0003190F01B0
Shop #: WSC 00191 264 15243
VCID: 2540C908ECE1076ED9-8070
5 Faults Found:
049682 - Steering Column Control Module
U0212 - 008 - No Communications - Intermittent
Freeze Frame:
Fault Status: 00101000
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 221575 km
Time Indication: 0
Date: 2022.02.11
Time: 14:53:40
Freeze Frame:
RPM: 1672 /min
Load: 22.7 %
Speed: 55.0 km/h
Temperature: 93.0°C
Temperature: 28.0°C
Absolute Pres.: 1030.0 mbar
Voltage: 12.954 V
049425 - No Communication with Battery Energy Control Module
U0111 - 008 - - Intermittent
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 221575 km
Time Indication: 0
Date: 2022.02.11
Time: 14:53:44
Freeze Frame:
RPM: 1719 /min
Load: 19.6 %
Speed: 57.0 km/h
Temperature: 93.0°C
Temperature: 28.0°C
Voltage: 13.208 V
012425 - Signal Line for Fuel Pump Electronics
P3089 - 002 - Electrical Malfunction - Intermittent
Freeze Frame:
Fault Status: 00100010
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 223026 km
Time Indication: 0
Date: 2008.04.03
Time: 12:08:45
Freeze Frame:
RPM: 752 /min
Load: 10.2 %
Speed: 0.0 km/h
Temperature: 94.0°C
Temperature: 66.0°C
Absolute Pres.: 1020.0 mbar
Voltage: 12.446 V
005634 - Power Supply Terminal 30
P1602 - 002 - Voltage too Low - Intermittent
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 0 km
Time Indication: 0
Freeze Frame:
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Temperature: -40.0°C
Absolute Pres.: 0.0 mbar
Voltage: 0.000 V
006435 - Please Check DTC Memory of ECU Number 2
P1923 - 008 -
Freeze Frame:
Fault Status: 01101000
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 223259 km
Time Indication: 0
Date: 2022.05.29
Time: 15:10:55
Freeze Frame:
RPM: 140 /min
Load: 55.3 %
Speed: 0.0 km/h
Temperature: 54.0°C
Temperature: 20.0°C
Absolute Pres.: 1010.0 mbar
Voltage: 10.541 V
Readiness: 0010 0000
Address 02: Auto Trans Labels: 09E-927-156.lbl
Part No SW: 4F5 910 156 P HW: 09E 927 156 D
Component: AG6 09E 5,0TFSI 250 0020
Revision: --H04--- Serial number: 0002366
Coding: 0000001
Shop #: WSC 02152 785 00200
VCID: 356019485C4177EE69-8060
No fault code found.
Address 03: ABS Brakes Labels: 4F0-910-517.lbl
Part No SW: 4F0 910 517 AJ HW: 4F0 614 517 AR
Component: ESP8 quattro H01 0130
Revision: 00000000 Serial number: 00000000000000
Coding: 0020931
VCID: 6CD6FC2C4F8BF62646-8038
Address 05: Acc/Start Auth. Labels:. 4F0-910-852.clb
Part No SW: 4F0 910 852 B HW: 4F0 905 852 E
Component: FBSAUDIC6 ELV H05 0100
Revision: 00H05000 Serial number: 10602501153369
Coding: 0000151
Subsystem 1 - Part No: 4F0 910 132 G
Component: FBSAUDIC6 EZS H03 0020
Subsystem 2 - Part No: 4F0 910 335 B
Component: FBSAUDIC6 KSG H02 0020
Address 06: Seat Mem. Pass Labels: None
Part No SW: 4F0 910 760 HW: 4F0 959 760
Component: Sitzmemory BFS H04 0050
Revision: 00000000 Serial number: 00000000896400
Coding: 0078944
VCID: 61C89D18B849AB4EE5-8034
Address 07: Control Head Labels: 4F0-910-7xx-07-H.clb
Part No SW: 4F0 910 732 K HW: 4E0 035 729 A
Component: Interfacebox H43 5140
Revision: 00000000 Serial number: 351H0087567687
Coding: 0031002
Shop #: WSC 02556 785 00200
VCID: 2B543F308A05311E0F-807E
Subsystem 1 - Part No: 4F0 910 609 E
Component: Bedienteil MMIC6H01 0060
Subsystem 2 - Serial number: 00000001132431
Subsystem 3 - Serial number: 0122.07.080000000100010471ÿ
Subsystem 4 - Serial number: 010471ÿ
1 Fault Found:
01310 - Level Control System Control Module (J197)
004 - No Signal/Communication
Freeze Frame:
Fault Status: 01100100
Fault Priority: 5
Fault Frequency: 1
Reset counter: 39
Mileage: 223261 km
Time Indication: 0
Date: 2022.05.29
Time: 15:24:00
Address 08: Auto HVAC Labels: 4F0-910-043.clb
Part No SW: 4F0 910 043 A HW: 4F2 820 043 Q
Component: KLIMABETAETIGUNGH30 0020
Revision: 00000054 Serial number: 00000030490412
Coding: 0525578
Shop #: WSC 00198 210 83109
VCID: 1C36ECECDFABC6A676-8048
Address 09: Cent. Elect. Labels: 4F0-910-279.lbl
Part No SW: 4F0 910 279 M HW: 4F0 907 279 A
Component: ILM Fahrer H21 0310
Revision: 00000000 Serial number: 4F0907279
Coding: 0115121
VCID: 33642750523569DE47-8066
Subsystem 1 - Part No: 4F2 910 113 B Labels: 1KX-955-119.CLB
Component: Wischer AudiC6 H06 0190
Coding: 00064784
Shop #: WSC 02556
Subsystem 2 - Part No: 8K0 910 557 Labels: 8K0-955-559.CLB
Component: REGENLICHTSENSORH04 0003
Coding: 00146221
Shop #: WSC 02556
Address 0E: Media Player 1 (R199) Labels:. 4E0-035-785.lbl
Part No SW: 4E0 035 785 F HW: 4E0 035 785 C
Component: SG ext.Player H15 0850
Revision: 00000000
Coding: 010000
Shop #: WSC 00000 000 00000
VCID: 2B543F304A05311E0F-807E
Address 0F: Digital Radio Labels: None
Part No SW: 4E0 910 563 C HW: 4E0 035 563
Component: DAB-Tuner H41 0830
Revision: 00000001 Serial number: KE1276W7200827
Coding: 0000001
VCID: 2446D40CE7DBFE66CE-8070
Address 11: Engine II Labels:. 07L-910-552-BUH2.clb
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 255
Mileage: 0 km
Time Indication: 0
Freeze Frame:
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Voltage: 0.000 V
Address 14: Susp. Elect. Labels: None
Part No SW: 4F0 910 376 HW: 4F0 907 376
Component: J250 DRC FahrwerH02 0020
Serial number: 00870000236900
Coding: 0000000
Shop #: WSC 131071 1023 2097151
VCID: 64C6940CA75BBE660E-8030
Address 15: Airbags Labels: 4F0-910-655-8R.clb
Part No SW: 4F0 910 655 E HW: 4F0 959 655 B
Component: 4F AIRBAG AUDI8RH30 0280
Revision: 09H30000 Serial number: 0037LD0Z9ND
Coding: 0013382
Shop #: WSC 02325 785 00200
VCID: 2958C53880F9230EFD-807C
Subsystem 1 - Serial number: 6332CSME3E114250Y
Subsystem 2 - Serial number: 6342CSME3E114227$
Subsystem 3 - Serial number: 6352QSME150407240
Subsystem 4 - Serial number: 6362QSME70020C087
Subsystem 5 - Serial number: 63734SME750F1B2DC
Subsystem 6 - Serial number: 63834SME3B023B04-
Address 16: Steering wheel Labels: 4F0-910-549.lbl
Part No SW: 4F0 910 549 A HW: 4F0 953 549 D
Component: J0527 0410
Revision: 00H03000 Serial number: 90055082190317
Coding: 0112142
VCID: 275CC30096ED157EEB-8072
Subsystem 1 - Part No: XXXXXXXXXXX
Component: E0221 H06 0030
Address 17: Instruments Labels: 4F0-910-xxx-17.lbl
Part No SW: 4F0 910 930 D HW: 4F0 920 983 D
Component: KOMBIINSTR. M73 H23 0020
Revision: 00400000 Serial number: 8CY39C678
Coding: 3153408
Shop #: WSC 19098 004 1048576
Address 19: CAN Gateway Labels:. 4L0-910-468.clb
Part No SW: 4L0 910 468 A HW: 4L0 907 468 B
Component: J533__Gateway H06 0060
Revision: 00H06000 Serial number: 1100B08730003F
Coding: F5D5FFF7703E0602
VCID: 2D503128B4113F2E11-8078
Address 1E: Media Player 2 Labels: 4E0-910-111.lbl
Part No SW: 4E0 910 110 E HW: 4E0 035 110 A
Component: MP3-Changer H47 0390
Revision: 00047003 Serial number: AUZ5ZBH8553300
VCID: 1A3AEAF4D59FB89664-804E
Address 36: Seat Mem. Drvr Labels: None
Component: Sitzmemory FS H04 0050
Coding: 0074858
Address 37: Navigation Labels: 4E0-910-88x-37.lbl
Part No SW: 4E0 910 888 E HW: 4E0 919 887 M
Component: MNS ECE H52 1050
Revision: 00000000 Serial number: 364HZ087809253
Shop #: WSC 00568 210 75650
VCID: 306E285CA32352C63A-8064
Address 42: Door Elect, Driver Labels: 4F0-910-793-42.lbl
Part No SW: 4F0 910 793 N HW: 4F0 959 793 N
Component: TSG FA H05 0240
Revision: 00000000 Serial number: Hs?
Coding: 0028410
1 Fault Found:
00920 - Heated Outside Mirrors; Driver Side (Z4) / Passenger Side (Z5)
012 - Electrical Fault in Circuit
Freeze Frame:
Fault Status: 01101100
Fault Priority: 3
Fault Frequency: 1
Reset counter: 39
Mileage: 223261 km
Time Indication: 0
Date: 2022.05.29
Time: 15:23:58
Address 46: Central Conv. Labels:. 4F0-910-289.lbl
Part No SW: 4F0 910 289 K HW: 4F0 907 289 K
Component: Komfortgeraet H27 0220
Revision: 02200027 Serial number: 01131774600000
Coding: 3549947
VCID: 326A2254AD2F60D64C-8066
Subsystem 1 - Part No: 1K0 951 605 C
Component: LIN BACKUP HORN H03 1301
Subsystem 2 - Part No: 4F0 910 177
Component: Innenraumueberw.H01 0020
Address 47: Sound System
Cannot be reached
Address 4F: Centr. Electr. II Labels: 4F0-910-280.lbl
Part No SW: 4F0 910 280 HW: 4F0 907 280 G
Component: ILM Beifahrer H12 0100
Revision: Serial number: 00000000006681
Coding: 0011111
VCID: 5EB2A6E4893794B6D8-800A
Address 52: Door Elect, Pass. Labels: 4F0-910-793-52.lbl
Part No SW: 4F0 910 793 N HW: 4F0 959 792 N
Component: TSG BF H05 0240
Revision: 00000000 Serial number: eb
Coding: 0028410
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 39
Mileage: 223261 km
Time Indication: 0
Date: 2022.05.29
Time: 15:23:58
Address 53: Parking Brake Labels: 4F0-910-801.clb
Part No SW: 4F0 910 801 C HW: 4F0 907 801 A
Component: EPB CDEC0080 H04 0080
Revision: --H04---
Coding: 0008021
Shop #: WSC 02197 785 00200
VCID: 204ED81CF3C3E246AA-8074
Address 55: Headlight Range Labels: 4F0-910-357.lbl
Part No SW: 4L0 910 357 HW: 4L0 907 357
Component: AFS 1 H01 0040
Coding: 0000016
Shop #: WSC 00045 210 175712
VCID: 69D885384079E30E3D-803C
Subsystem 1 - Part No: 4F0 941 329 D
Component: AFS-Modul links H01 0010
Subsystem 2 - Part No: 4F0 941 329 D
Component: AFS-Modul rechtsH01 0010
Address 56: Radio Labels: 4E0-910-541.lbl
Part No SW: 4E0 910 541 Q HW: 4F0 035 541 L
Component: TUNER EU/US/RDW H42 0620
Revision: 00000000 Serial number: 394H-087923317
Coding: 0000001
VCID: 2E523624B917443628-807A
Address 57: TV Tuner Labels: None
Part No SW: 4E0 910 148 D HW: 4E0 919 148
Component: R78 TVHybridDVB 0440
Revision: R0H06000 Serial number: 76300801712202
Coding: 0000303
Address 61: Battery Regul. Labels: 4F0-910-181.lbl
Part No SW: 4F0 910 181 F HW: 4F0 915 181 B
Component: J0644 BEM H12 0760
Revision: 00000000 Serial number: 00000000131023
Subsystem 1 - Part No: 4F0 915 105 D
Component: von VA0 VA0391023N
Coding: 34463039313531303544205641305641303339313032334E
Shop #: WSC 54786 001 1048576
Address 62: Door, Rear Left Labels: 4F0-910-795.lbl
Part No SW: 4F0 910 795 G HW: 4F0 959 795 G
Component: TSG HL H04 0220
Coding: 0027690
Address 65: Tire Pressure Labels: 4F0-910-273-HI.lbl
Part No SW: 4F0 910 273 C HW: 4F0 907 273 A
Component: Reifendruck 3 H05 0100
Revision: 00050100 Serial number: 00000900031072
Coding: 0222625
VCID: 2344D710E2D5F95EB7-8076
1 Fault Found:
02214 - Tire Pressure Warning
000 - - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 1
Fault Frequency: 25
Reset counter: 66
Mileage: 222331 km
Time Indication: 0
Date: 2022.03.05
Time: 08:56:13
Freeze Frame:
(no units): 0.0
Temperature: 5.0°C
Error Code: 2
Pressure: 1.55 bar
Pressure: 2.37 bar
Pressure: 2.40 bar
Pressure: 2.37 bar
Address 6C: Back-up Cam. Labels: 4L0-910-441.clb
Part No SW: 4F0 910 441 A HW: 4L0 907 441 A
Component: J772__Rearview 0050
Revision: --H12--- Serial number: 525PA8-J8730C6
Coding: 1020505
Shop #: WSC 00000 785 00200
VCID: 1E32E6E4C9B7D4B698-804A
Address 6D: Trunk Elect. Labels: Redir Fail!
Part No SW: 4F9 910 591 HW: 4F9 827 851 F
Component: ValeoHeckdeckel H25 0290
Revision: --H25001 Serial number: E5030000B
Shop #: WSC 98765 666 38354
Subsystem 1 - Part No: 4F9 910 592
Subsystem 2 - Serial number: E5030100B
Subsystem 3 - Serial number: RD05.08.08--H25001001A0017ÿ
Subsystem 4 - Serial number: 1A0017ÿ
5 Faults Found:
01330 - Central Control Module for Central Convenience (J393)
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 3
Fault Frequency: 3
Reset counter: 61
Time Indication: 0
01331 - Door Control Module; Driver Side (J386)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 7
Reset counter: 78
Time Indication: 0
00456 - Control Module for Access and Start Control (J518)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 60
Reset counter: 61
Mileage: 221575 km
Time Indication: 0
Date: 2022.02.11
Time: 14:53:47
01299 - Diagnostic Interface for Data Bus (J533)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 33
Reset counter: 61
Time Indication: 0
01336 - Company Data Bus for Comfort System
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 78
Time Indication: 0
Address 72: Door, Rear Right Labels: 4F0-910-795.lbl
Part No SW: 4F0 910 795 G HW: 4F0 959 794 G
Component: TSG HR H04 0220
Coding: 0027690
Address 76: Park Assist Labels: 4Fx-910-283.lbl
Part No SW: 4F1 910 283 A HW: 4F1 919 283 A
Component: Parkhilfe 8-Kan H12 0120
Revision: 00H12000 Serial number: 64330819700497
Coding: 0221116
Address 77: Telephone Labels: 4F1-910-336.lbl
Part No SW: 4F1 910 336 C HW: 4F1 862 335
Component: BTA H11 0960
Revision: 00H11000 Serial number: 00000007587935
Coding: 0050021
End-------------------------(Elapsed Time: 05:19)--------------------------
