Bad HPFP or leaking injectors?
Posted: Tue May 31, 2022 12:59 pm
Been having slight issues with rough idling and such so decided to check the fuel pressure using VCDS.
See attached images. First is on idle and second is with ign on only.
Question is, how do I know if its hpfp's or injectors thats leaking?
Also having issues with the flaps on both banks, stuck closed which will be resolved in the very near. Exept the fault codes, what kind of symptoms is stuck valves giving?
Also wonder what normal intake pressure/vacuum is on idle?
What spark plugs and gap have been known to work best on these engines?
RPM sensor, think it's G28? Known to fail? Were is that one mounted?
