Squealing noise on start up
Posted: Tue Aug 24, 2021 9:39 pm
by jpr36
Evening all, over last few weeks occasionally on start up a high pitched squeal or screech which disappears after about 5-10 seconds. Thinking a belt or tensioner problem but any thoughts welcome, thanks
Re: Squealing noise on start up
Posted: Tue Aug 24, 2021 11:32 pm
by Jim Haseltine
You've only got one belt and tensioner on the engine - it drives the alternator. Not only was the belt on my car very badly cracked in a number of places but the tensioner had seized slightly - some lubrication and working the pulley back and forth with a long lever freed it up. A replacement belt was peanuts from a conveniently local supplier.
Posted: Wed Aug 25, 2021 2:50 pm
by jpr36
Thanks Jim. If it is that, is it front end off to replace?
Posted: Wed Aug 25, 2021 6:27 pm
by Jim Haseltine
Bumper off most certainly. You might be able to get away with backing off the radiator bolts almost to the ends then pulling the rad forwards as far as you can get it. Depends what tools you have access to and how big your arms are - it'll be tight for elbow room whatever the answer is.
Posted: Wed Aug 25, 2021 8:10 pm
by BobBobson
The Belt is doable with just the bumper off and the oil and power steering fluid coolers swing out of the way. If you’re replacing the tensioner and pulley then imho you’ve got no chance without moving the radiator carrier forward a few inches.
Posted: Thu Aug 26, 2021 10:02 pm
by jpr36
Thanks guys
Posted: Sat Aug 28, 2021 10:48 am
by don0301
I get squealing noises with FOT. Only happens with passengers, weirdly. :wink:
