Oil change and crusty coolant pipes
Posted: Sat Sep 28, 2019 6:53 pm
by Pinkfoot
Took about 2.5 hours all told and was easy.
Hardest part is the under tray.
It's a bit fiddly but not difficult.
If anyone knows the size of the coolant pipes ,I would like to know as we will replace the bad bits with rubber/silicon and probably get some metal one fabricated at a later date.
Re: Oil change and crusty coolant pipes
Posted: Mon Sep 30, 2019 6:36 am
by WooshNI
Following
Posted: Sun Oct 27, 2019 4:50 pm
by Pinkfoot
Sorted the coolant pipes today.
Took around three hours
Posted: Sun Oct 27, 2019 5:05 pm
by Pinkfoot
For some reason I cant load the rest of the pictures .
We replaced the pipes with silicon hose and then spiral plastic hydraulic hose protector.
Posted: Mon Oct 28, 2019 1:38 pm
by Albigularis
Pinkfoot wrote: ↑Sun Oct 27, 2019 5:05 pm
Try upload them onto imgur or something and then share the link here, I would love to see them
Posted: Tue Nov 19, 2019 7:48 am
by WooshNI
Any problems with airlocks in the cooling system?
Posted: Tue Nov 19, 2019 11:42 am
by Pinkfoot
Filled it up with coolant ,let it idle for a while and then took it for a run.
Temp started to rise so switched off for a few minutes ,fired her up again and back to normal.
Posted: Wed Nov 20, 2019 11:58 am
by c3nturi0n
Great work... now you are good with at least 7+ years of worry free motoring on coolant side of things.
While you are doing the job, check the state of your rads as they tend to start deteriorating after 10 or so years.
