Diverter/Recirc Valves part#'s
Posted: Mon May 13, 2019 9:26 am
by groupA
Hi Gents,
Anyone have part numbers for the diverter valves? im aware they are a integrated with the lower section of the airbox. Unfortunately my indie only seems to be able to find a price for a full airbox replacement which is 400 pounds per side
Re: Diverter/Recirc Valves part#'s
Posted: Mon May 13, 2019 10:01 am
by c3nturi0n
hi - if recir valve is indeed an issue, this would be your best option -
https://www.forgemotorsport.co.uk/Turbo ... --756.html. Note you'd need two valves (one for each side). A job requires some DIY as OEM ones are integrated in the air box lower assembly. There is a really good thread on this forum that talks about How to.
Hope that helps.
Posted: Mon May 13, 2019 3:01 pm
by Toady1
As above. Your indie is correct, all part of the lower box on these cars. I replaced mine with the Forge items.
Posted: Tue May 14, 2019 8:12 am
by groupA
Thanks for the responses guy's. Does look like forge items made to fit is the best option
Reason im looking at replacing the valves is due to a code thrown in relation to the N249 valve. Have already replaced the N249 so figured DV's was the the next troubleshooting step. Any ideas?
Address 01: Engine Labels: 07L-910-552-BUH1.clb
Control Module Part Number: 4F5 910 552 HW: 4F1 907 552 A
Component and/or Version: 5.0L V10/4V TFSI ª0080
Software Coding: 01050003190F02B0
Work
Shop Code: WSC 63809 741 90035
VCID: 6597B31ED96D22CF0DB-8030
008801 - Boost Pressure Control Valve (N249)
P2261 - 008 - Mechanical Malfunction
Freeze Frame:
Fault Status: 01101000
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 105122 km
Time Indication: 0
Date: 2019.05.04
Time: 08:47:33
Freeze Frame:
RPM: 4249 /min
Load: 9.4 %
Speed: 108.0 km/h
Temperature: 97.0°C
Temperature: 42.0°C
Absolute Pres.: 980.0 mbar
Voltage: 14.351 V
Posted: Tue May 14, 2019 10:22 am
by Toady1
Where did you get the N249 valve from, I was led to believe they were on back order? Have you checked for vacuum leaks before replacing the BOV's? Its not a simply job and most garages won't want to do it as its a 'modification'.
Posted: Wed May 15, 2019 6:18 am
by groupA
Im in NZ but the N249 came from the fatherland (was early Feb so must have still been available at that point). Will start working through the vacuum lines thanks for the advice
