Page 1 of 2
Winter tyres
Posted: Mon Nov 19, 2018 4:51 pm
by c3nturi0n
hi guys,
i'm contemplating on an idea to take my RS to the Alps during Christmas break... one really qq re tyres. Would it be worth going for 275 40/20's instead of original 35 fitment for "extra" comfort?
Assume this is / will be safe to use on Quattro so long as all 4 x tyres are of same height?
Re: Winter tyres
Posted: Tue Nov 20, 2018 9:45 am
by Jim Haseltine
275/35 = 96 (approx). 275/40 = 110, so the tyre wall will be approx 14mm higher (depending on make and model as all tyre sections are nominal measurements).
You could well get some rubbing at the back especially when loaded and at the front on full lock.
Re: Winter tyres
Posted: Thu Nov 22, 2018 3:38 pm
by c3nturi0n
cheers Jim.
Re: Winter tyres
Posted: Fri Nov 23, 2018 10:14 am
by Jim Haseltine
And it should go without saying (but I will) the speedo will under read by about 4%.
Re: Winter tyres
Posted: Fri Nov 23, 2018 12:19 pm
by c3nturi0n
hahah :)... that's a nice one.
reason why i'm asking is that 35 profile are tad challenging to source at acceptable prices and I have a hard time convincing myself to spend a "grand+" on something I'd only use for single trip to the Alps. Hence the ask for 40 profile that are somewhat more cost-effective (but with caveats that you outlined Jim).
Re: Winter tyres
Posted: Sat Nov 24, 2018 2:50 am
by Doug_RS6
Could try a 265/40
Re: Winter tyres
Posted: Sat Nov 24, 2018 5:31 pm
by c3nturi0n
thanks Doug.
Wonder if anyone tried 265/40 20's and how do they fit to a car?
Re: Winter tyres
Posted: Sat Nov 24, 2018 6:46 pm
by Jim Haseltine
Dunno, but I'll tell you this, once you've driven with winter tyres you'll want to fit them in this country when the temperature drops. The grip is amazing compared to summer or all weather tyres. There are downsides though, they don't last long when things get warmer and they're usually rather noisy on dry roads.
Re: Winter tyres
Posted: Sat Nov 24, 2018 7:00 pm
by HPsauce
I've probably said this before, but I find the best method is to have a second set of wheels with winter tyres fitted.
Smaller diameter (assuming the car brake geometry allows this) with deeper tyres to maintain the same rolling radius.
Re: Winter tyres
Posted: Sun Nov 25, 2018 8:26 pm
by c3nturi0n
HPsauce wrote:I've probably said this before, but I find the best method is to have a second set of wheels with winter tyres fitted.
Not much other than std would fit RS tbh... hence the ask to see what options if any are out there.
Re: Winter tyres
Posted: Sun Nov 25, 2018 9:31 pm
by Doug_RS6
thanks Doug.
By reducing the width you reduce the radius too as the 40 is a percentage of the width. It will also very slightly pull the sidewalls in giving a little more clearance.
Re: Winter tyres
Posted: Mon Nov 26, 2018 11:28 am
by Jim Haseltine
265/40 is 106mm - approx 10mm higher than a 275/35 sidewall.
Re: Winter tyres
Posted: Mon Nov 26, 2018 12:22 pm
by Doug_RS6
You will lose some of that 10mm though as the sides pull in giving a more rounded sidewall.
Re: Winter tyres
Posted: Mon Nov 26, 2018 12:38 pm
by c3nturi0n
Guess car won’t loose much on stability and performance etc.?
Re: Winter tyres
Posted: Mon Nov 26, 2018 1:54 pm
by Doug_RS6
I wouldn't of thought so. I mean they compound and design of the tyres will be the most obvious change.
