Page 1 of 2
RS6 C6 front brake kit
Posted: Thu Feb 16, 2017 10:38 am
by Andyevo
Hi all,
Came across this big brake kit for the front of a C6 RS6. Maybe a good upgrade at a reasonable cost, 8 pot calipers, 405mm diameter floating discs, race brake pads and braided brake lines £1889 plus postage.
http://pbbrakes.com/audi-rs6-c6-08-11-f ... e-kit.html
Anyone tried this kit?
Just an idea for you c6 rs6 owners
Andy
Re: RS6 C6 front brake kit
Posted: Thu Feb 16, 2017 12:10 pm
by Studiowise
Interesting, mine could definitely do with a bit more stopping power. I wonder what I'd get for my current OEM setup on eBay.
____________________________________________________
RS6 C6 MTM Map Engine & Gearbox STAGE2
Posted: Thu Feb 16, 2017 12:14 pm
by Andyevo
Studiowise wrote:Interesting, mine could definitely do with a bit more stopping power. I wonder what I'd get for my current OEM setup on eBay.
I think the OEM kit from rs6 c6 fetches around a grand on eBay in good nick
Posted: Thu Feb 16, 2017 12:16 pm
by Studiowise
Andyevo wrote:Studiowise wrote:Interesting, mine could definitely do with a bit more stopping power. I wonder what I'd get for my current OEM setup on eBay.
Thx Andyevo
Well that's a bit of a no-brained then as I was liking to spend £800 on the brakes next time round so I could get this upgraded kit and then recoup a chunk of the outlay. Hmmm.
Posted: Thu Feb 16, 2017 12:19 pm
by Andyevo
Studiowise wrote:Andyevo wrote:Studiowise wrote:Interesting, mine could definitely do with a bit more stopping power. I wonder what I'd get for my current OEM setup on eBay.
Thx Andyevo
Your welcome, I can't tell you what this upgraded kit is like but I have used performance friction brake products on my evo's and they performed really well
Posted: Thu Feb 16, 2017 12:20 pm
by Studiowise
Thx Andyevo
might do some digging around to see if anyone else has mentioned them on 'other' forums
Posted: Thu Feb 16, 2017 7:14 pm
by rtd
If the decision is steels over ceramics I probably wouldn't look any further than these
viewtopic.php?f=47&t=122027
Posted: Fri Feb 24, 2017 8:52 pm
by Ceveman73
Problem with these kits is that they don't produce vehicle specific piston sizes, so it's hit and miss whether the piston area will be compatible with your master cylinder. If the piston area is too large in relation to the master cylinder, you end up getting a mushy pedal, and have to pump the pedal before the brakes activate fully. I made this mistake a few years ago, buying one of these brings generic kits from a Taiwanese company. Look lovely, but don't work.
Companies like Brembo, AP and Stoptech produce specific kits for designed to work for a particular application, with matched piston sizes, so that the pedal travel is optimised.
Food for thought. Buy cheap, buy twice...
Posted: Fri Feb 24, 2017 11:42 pm
by IanH755
Before going with the AP Racing 420mm kit I also looked at these but couldn't find any decent "independent" reviews any later than mid-2013, just some very positive owners reviews. Their actual name is/was Phat Boy Brakes and they are made in the same factory as K-Sport brakes so are a cheaper clone of those.
In the end I chose AP-Racing for a number of reasons but my main one for AP vs PB Brakes as they're based in the UK so if there are any issues it's much easier to get things sorted, plus they're a "known" motorsport quality manufacturer with a massive R&D section so I knew everything would be built to a high quality, work at extremes and be durable.
In the end, once you've added £250 for 2 piece rotors (now upto £1800), £200 for shipping, £90 Duty and £400 VAT, it's £2500 for the kit which isn';t so cheap for a kit coming from Taiwan.
Posted: Mon Feb 27, 2017 1:42 pm
by TomRS
Truly an epic kit as Ian said the AP 410's lasted 10+ laps of croft circut without any fade whatsoever they really are a stunning kit for the money, reccommend a brake fluid upgrade to AP's RadiCal R4 fluid or RBF600 etc.
Posted: Wed Mar 01, 2017 8:43 pm
by RossH14
i've just fitted teh AP kit (as per Tom) and looking fwd to giving them a work out
Ross
Posted: Wed Mar 01, 2017 8:47 pm
by IanH755
Make sure you give them a very good bedding in. Mine were a bit "meh!" until I got the AP DS25 pads hot enough to start gassing off (took about 8 70-10mph emergency stops) but once bedded, HOLY POOP!
Posted: Tue Mar 07, 2017 2:58 pm
by TomRS
IanH755 wrote: ↑Wed Mar 01, 2017 8:47 pm
Still happy with the RS6 Ian, i'll have to give you a buzz later on!
Posted: Tue Mar 07, 2017 4:00 pm
by IanH755
I'm available at work til 6 most days matey!
Posted: Mon Jul 10, 2017 12:54 pm
by Andyevo
Anyone fitted one of these kits or got any views on it?
https://www.ebay.co.uk/itm/152618025261
