The puffs of blue smoke issue
Posted: Mon Jan 23, 2017 6:52 pm
I really appreciate the guidance of members that have experienced this problem before as there appears to be a few different avenues to investigate.
The car has done 68,000 miles (110,000kms) and only got the power upgrades at 97,000kms
Mods include: Full decat, Performance Airfilters, REVO STAGE 2 (boost 1.2 - 1.4 depending of fuel quality) I have a SPS controller with x 4 settings for the ECU, I run the car on REVO standard most of the time.
Audi South Africa told be it was the Oil Collector Part No. 07L 145 232 A
As the car only puffs blue smoke under initial throttle and then blows clean, and uses about 500ml of oil every 4,000km (2,500miles)
The possible causes from what I've read are:
Oil separator / Crankcase Pressure Valve leak
Turbo Blowby and or weak recirculating valves (I have got 249 errors but not consistently)
Turbo boost solenoid (I have lost boost pressure when the car is very hot)
Stuck injector (but I guess it would smoke on one side)
I'd rather not talk about bore wash, stuck rings and other major engine problems
If there is a process of illumination that I should follow it would be great to know, as Audi will just keep changing parts until the problems goes away.
Huge thanks, Craig
Huge thanks, Craig
