Iso fix help
Posted: Sun Oct 30, 2016 9:08 pm
by Shaneyboi88
Ive bought a rs6 this weekend but didnt realise id dosnt have iso fix in the back can this be fitted or will i have to put up with strapping the seatbelt round everytime.
Re: Iso fix help
Posted: Sun Oct 30, 2016 10:33 pm
by Nosillad
I thought all C6 models had ISO fix in back and front passenger, mine certainly does, it's buried in the seat unlike some of the other model audis where they protrude out but I think if you take another look it's in there
Re: Iso fix help
Posted: Sun Oct 30, 2016 10:34 pm
by doodlebug
Agreed, it was standard but it is buried.
Re: Iso fix help
Posted: Sun Oct 30, 2016 11:11 pm
by Shaneyboi88
I have the buckts in the front so i know they wont be there. Anyone know how the bottom half of the seat comes out because i really cant find them lol
Re: Iso fix help
Posted: Mon Oct 31, 2016 10:13 am
by AdrianE
They are there, but they're not obvious!
I looked on the Plus I viewed recently and ended up not using them on test drive as I didn't want to damage the leather without some spreaders available.
Audi sells guide funnels under part number 8R0 019 233A for £15 a pair before any discount - I would go for those over generic ones as they should minimise the effect on the leather.
If you find the point where the base and backrest meet and wiggle your fingers between you will find the metal bars more or less in line with the vertical stitching IIRC
Re: Iso fix help
Posted: Tue Nov 01, 2016 8:36 am
by Shaneyboi88
Ive mannaged to find 2 holes behind the seat where im assuming that the isofix bolts to so ill get one ordered. Now i still cant mannage to get the bottom half oc the seat out dose anybody know how it comea out i dont wanna break anything lol
Re: Iso fix help
Posted: Tue Nov 01, 2016 9:02 am
by doodlebug
It doesn't come out.
Re: Iso fix help
Posted: Tue Nov 01, 2016 10:07 am
by Shaneyboi88
It must come out to be able to fit the bars in for iso fix and i mean the rear seat just incase one of us is confused lol
Re: Iso fix help
Posted: Tue Nov 01, 2016 12:51 pm
by Jim Haseltine
The usual method for Audi non-folding seat benches is to lift the bottom of the bench whilst pushing it backwards at a point on the base about half way along each seating section.
You may need to use a fair amount of force.
The bases usually have thick wire loops that insert into floor mounted plastic clips. The clips (4B0886373 I think) are fragile and I suspect should be treated as a one-time fitting, with a strong possibility that they'll break when you remove the base.
Re: Iso fix help
Posted: Tue Nov 01, 2016 9:25 pm
by Shaneyboi88
Ive mannaged to get the front up like u said to pull back in the middle of each seat but then theres something at the back holding it down do i just pull it harder i dnt wanna break anything haha
Re: Iso fix help
Posted: Wed Nov 02, 2016 7:58 am
by AdrianE
Why are you trying to remove the bench? It's not necessary to access the Isofix if that's what you're attempting to do......
Re: Iso fix help
Posted: Wed Nov 02, 2016 9:22 am
by Shaneyboi88
Theres no isofix so im trying to remove so i can install it then put the bench back. Just dnt wanna break anything lol
Re: Iso fix help
Posted: Wed Nov 02, 2016 2:43 pm
by AdrianE
oh ok, I'm very surprised it's not there. My 2002 S8 had it as standard and every VAG car I've had later than that has had it too. When it was optional you usually got it alongside the option to disable the front passenger airbag with a key in the glovebox, before it became a requirement to be fitted.
Re: Iso fix help
Posted: Wed Nov 02, 2016 4:35 pm
by Shaneyboi88
I phoned audi today thay said my car had them from new. So i decided to take the seat out when i got home.
100% there is no isofix in there just 2 holes on each side so somone must of taken it out for some reson
Re: Iso fix help
Posted: Fri Nov 04, 2016 11:19 am
by TomRS
Shaneyboi88 wrote:I phoned audi today thay said my car had them from new. So i decided to take the seat out when i got home.
Mine has them. as above i thought all were fitted as standard.
If someone has removed them then im not sure where you would get the ISOFIX from, maybe try TPS? there is an RS6 breaking on eBay most of its gone but i bet the ISOFIX is still there, i bought a full front strut off it to send away to get my brakes made up.
