BOV and boost pressure
Posted: Sat Aug 27, 2016 12:46 pm
by Audi-RS6-R
Hey,
I would know from the RS6 drivers with more then 800hp how much boost pressure you are running and which BOVs you are using to hold the pressure?
Greetings from Germany
Re: BOV and boost pressure
Posted: Sat Aug 27, 2016 4:40 pm
by rs6_sid
Also interested in this and the location of them as if they are like the smaller Tfsi engine the diagram tears
Posted: Tue Aug 30, 2016 4:06 pm
by TomRS
rs6_sid wrote:Also interested in this and the location of them as if they are like the smaller Tfsi engine the diagram tears
They are located under the air boxes.. the valve sits directly in the air box almost like a "once piece" setup
Posted: Tue Aug 30, 2016 8:52 pm
by Audi-RS6-R
So nobody?
Are all "over 800HP drivers" driving with the OEMs with no problems in holding pressure?
Posted: Tue Aug 30, 2016 9:11 pm
by Trups
No issues with my 900 car. And I know it hasn't had an upgrade.
What's the issue with yours?
Posted: Tue Aug 30, 2016 10:17 pm
by Audi-RS6-R
I had issues...no boost over 1.4bar - I have now 2 Forges mounted...and running 1.7 - 1.8 bar
I was just curious, how others driving with more boost and OEM BOVs
Posted: Wed Aug 31, 2016 12:08 am
by rs6_sid
does anyone know if they are a diagram style as at a guess they will degrade and would want changing if they are anything like other vag dv's
any part numbers ect ?
Posted: Wed Aug 31, 2016 6:33 am
by Trups
I'm going to book in for a map tweek soon so if your still unsure il be able to find out.
Will boost not go down to the turbo tho? Mine is the TTH 950. I'm sure I read before you had the TTh 850?
Posted: Wed Aug 31, 2016 9:58 am
by TomRS
If your running a smaller turbo you may require more boost then the larger turbo... all the cars (that i know of) running 900+ are on stock BOV's running around 1.2-1.4 bar no more.
I wonder if more can be had from the stock turbo's applying this principal? then again you'd just end up with a crap droopy power curve so probably not worth it.
Posted: Wed Aug 31, 2016 8:43 pm
by GBR1198
apparently the stock turbos at 800ps are pretty naff compared to a TTe at 800+ the power curve is completely different.
Posted: Wed Aug 31, 2016 8:50 pm
by Audi-RS6-R
Well - I am running the TTH850 upgrades with 1.7 @overboost
Posted: Thu Sep 01, 2016 12:58 pm
by TomRS
GBR1198 wrote:apparently the stock turbos at 800ps are pretty naff compared to a TTe at 800+ the power curve is completely different.
Yeah i'd have thought so too, they are small turbos and wont flow well higher up the RPM.
I'll be going down the 3" downpipe (no engine removal) and a remap from MRC just to push power a little bit higher but nothing crazy, it'll be a long while before i upgrade any further!
Posted: Thu Sep 01, 2016 7:20 pm
by rs6_sid
I was keen on the downpipes as well Tom but I was a bit put off by the fact of one of the rear studs can snaps it's an engine or job if it does as its inaccessible !
