Page 1 of 2
420mm ceramic brake pistons
Posted: Tue Jul 05, 2016 11:11 pm
by Audi-RS6-R
Hey,
I guess my pistons of my ceramic callipers are not movin correctly anymore...they are very rusty
Somebody knows if there is a chance to get the pistons of the callipers to buy?
Greetings
Re: 420mm ceramic brake pistons
Posted: Wed Jul 06, 2016 12:31 am
by IanH755
The pistons need a special removal tool according to Alcon (
https://www.alconkits.com/tools-and-sup ... ool-detail) and you need to know if the pistons are Aluminium or Steel and their size too.
As the Calipers are Audi OEM, Alcon may not give you any information on the piston as Audi hold the rights to all the info (same issue I had finding Brembo info out).
Sorry thats not a lot of help but it may be better just to give them to a refurbishment company instead and let them deal with Alcon.
Posted: Wed Jul 06, 2016 10:08 am
by rs6_sid
You would be able to do them your self if the seals are good and you have a fair mechanical know how , get the Pistons cleaned up chemically and re coated as I imagine they have some kind of finish on them
Posted: Wed Jul 06, 2016 11:30 pm
by Golfather
I have a brand new set. PM sent.
However check your seals first - there was a recall to replace the seals on early calipers.
Posted: Thu Jul 07, 2016 12:36 am
by Audi-RS6-R
@Golfather...PM sent
I think the seals must be okay...I don't loose brake fluid...and according of my car history, they changed and replaced the disks & callipers twice
Posted: Fri Jul 08, 2016 7:15 am
by TomRS
Callipers changed twice? holy cow... must be something where you live that doesn't agree with your pistons.
Posted: Fri Jul 08, 2016 7:40 am
by Audi-RS6-R
Well, I don't live in the Sahara and neither in the North Pole
Posted: Fri Jul 08, 2016 7:47 am
by TomRS
Audi-RS6-R wrote:Well, I don't live in the Sahara and neither in the North Pole
hahaha! terrible that though, two replacements... and now the 3rd set gone? surely there's something a miss?
Posted: Fri Jul 08, 2016 8:22 am
by Quattro_RS6
I guess they use salt on the roads during wintertime in Germany as weell?
The pistons are actually stainless steel, but it's the backing plate to the brake pad which corrodes and leave rust around the pistons. Also, even if the pistons are stainless, they will get dirty, pitted and eventually start to restrict free movement.
The problem with the Alcon 8 piston calipers are that they do not have dust seals. It may be that they have internal dust seals, but still, they are not as good protected as the normal design found on Brembo and standard calipers.
Shpend; i think you have to disassemble the caliper, clean the pistons or buy new ones, and reassemble with new seals and grease. New pads is also wise to install looking at your pictures..
I add a couple of pictures of my own calipers before they were sent to refurbishment. You can easily see the pitting on the pistons, but if they were not stainless steel they would have been very corroded and completely brown. (The calipers are also yellow/gold in colour, but that's due to heat input on last years track day
Posted: Fri Jul 08, 2016 8:49 am
by IanH755
Quattro_RS6 wrote:The problem with the Alcon 8 piston calipers are that they do not have dust seals.
It might be because ceramic brakes get so hot (900'c) that they can't use external dust seals as they would melt and have internal seals only.
Posted: Fri Jul 08, 2016 9:17 am
by TomRS
Seems legit ian....
Although it seems odd that they would design something to be so... "bad" but again saying that ceramics are still very much a race car type addage and in those enviroments they are not suspect to salt/dirt.. they are also usually stripped and cleaned after every event.
Might be worth stripping down the calliper and cleaning it and the pistons every 5000 miles/ 6 months?
Posted: Fri Jul 08, 2016 9:29 am
by IanH755
It seems to be an issue with Alcons "early" pre 2006 designed OEM calipers. The newer C7 Brembo Ceramic calipers and newer aftermarket Alcon ones all come with dust seals now (no idea what it's made of).
Posted: Fri Jul 08, 2016 9:31 am
by Quattro_RS6
That could also be a reason for it, off course. Alcon is one of the leading provider of racing calipers, so i guess they know what they are doing
I actually burnt the rubber dampening plate on the pads last year at a track day..
Posted: Fri Jul 08, 2016 9:45 am
by Quattro_RS6
IanH755 wrote:It seems to be an issue with Alcons "early" pre 2006 designed OEM calipers. The newer C7 Brembo Ceramic calipers and newer aftermarket Alcon ones all come with dust seals now (no idea what it's made of).
Here's some interresting reading:
https://www.essexparts.com/cp9668-trail ... t-anodized
It may be that the C7 ceramic brakes with Brembo caliper is less track firendly, but more all year around-friendly.
Posted: Fri Jul 08, 2016 10:46 am
by IanH755
The Radi-Cal Calipers in the link above are what TomRS has had fitted (slightly different model) and what I'm getting fitted this month
