anyone knows where this noise come from? It sounds like a compressor...this high tone - making me crazy
Re: Strange noise
Posted: Fri Feb 26, 2016 6:15 pm
by kent_andy
Hmm sounds a bit dentist drill. Could be turbo or secondary air pump
Re: Strange noise
Posted: Fri Feb 26, 2016 6:25 pm
by IanH755
That sounds like the turbo. Can you hear the high tone noise after you have changed to a new exhaust, I see you are selling the MTM exhaust in your signature?
Re: Strange noise
Posted: Fri Feb 26, 2016 6:46 pm
by Audi-RS6-R
@Ian...No - no noise changing after exhaust change on this tone...Turbos? Sure? Because the tone is exactly getting high & low with the rpm - don't matter if I drive or not.
Always the same...Yes - MTM is for selling...
@Kent...how to test if it's the sec air pump?
Sorry for my english
Re: Strange noise
Posted: Fri Feb 26, 2016 7:06 pm
by Ungjaevel
Try turning off the AC. Difference?
Re: Strange noise
Posted: Fri Feb 26, 2016 7:11 pm
by Audi-RS6-R
@Ungjaevel... I tried that - no difference at this noise...
Re: Strange noise
Posted: Fri Feb 26, 2016 9:17 pm
by Audi-RS6-R
BTW.: My AC is always off...(winter)
But 10 min. ago I turn the AC on and the noise get louder...so what do you think?
Re: Strange noise
Posted: Sat Feb 27, 2016 11:46 am
by Terminator
Could be a worn bearing on the alternator or air con compressor.
The problem with leaving your air con off all the time during the winter is that the compressor seals can dry out causing leaks. Best to switch it on at least a couple of times a week.
Re: Strange noise
Posted: Sat Feb 27, 2016 1:27 pm
by blm70
Terminator wrote:Could be a worn bearing on the alternator or air con compressor.
This
People often turn their A/C off during winter as they think it only works when it's hot. A/C filters the air, even when using the heater, plus it stops the windscreen from fogging up by also drying the air. Fuel/power savings from not using it are negligible.
Re: Strange noise
Posted: Sat Feb 27, 2016 2:49 pm
by Audi-RS6-R
So u think the noise is coming from my AC compressor? Any solution for that?
Re: Strange noise
Posted: Sat Feb 27, 2016 3:07 pm
by Terminator
You need to take it to a competent, preferably Audi experienced mechanic to get the problem officially diagnosed.
It may be possible to rebuild the compressor if this is the problem, rather than have to buy a new one, which is not going to be cheap!
Re: Strange noise
Posted: Tue Mar 01, 2016 10:40 am
by Quattro_RS6
Try to diagnose the source of the noise with a "hear probe". It's a metal stick that you can hold on to different parts to hear the vibrations. Hopefully it's just your alternator, because dismantling the AC compressor means a lot of work..
I guess you have checked that the sound is not chaning when you turn the wheels? (i.e. the powersteering pump)
Re: Strange noise
Posted: Tue Mar 01, 2016 2:31 pm
by Audi-RS6-R
@Quattro_RS6 - the source is from the left side...and no changing sound by turning the wheels...
Re: Strange noise
Posted: Tue Mar 01, 2016 2:34 pm
by TomRS
Sounds like either Alternator or tensioner/idler pulleys... i have a slight whine from my P/S pump but im not worried, changed the fluid and its quieter so when it gets really noisy i'll replace it.
Re: Strange noise
Posted: Tue Mar 01, 2016 2:38 pm
by Audi-RS6-R
@TomRS - hope so you are right...but the noise is getting louder when I turn on the A/C :/
