Update: after 2 weeks of having one of the turbos replaced and two (2) of Boost Pressure Control Valve (N249) replaced also, car is driving very good and no signs of any power loss or any oil leakage anymore. However, was running a scan after the job and found the below mentioned errors. I saved the first log and cleared the errors, did a test drive and full day drive and errors never appear again. Today I was doing a scan and found out that errors back again! any idea what could be the reason??
Address 01: Engine (BUH) Labels: Redir Fail!
Part No SW: 4F1 910 552 E HW: 4F1 907 552 A
Component: 5.0L V10/4V TFSI ™0040
Revision: F1H05--- Serial number:
Coding: 01050000190F01B0
Shop #: WSC 01286 386 08256
VCID: 2643FAFD9199DB2EC1B-8073
3 Faults Found:
000665 - Boost Pressure Regulation
P0299 - 002 - Control Range Not Reached - MIL ON
Freeze Frame:
Fault Status: 11100010
Fault Priority: 2
Fault Frequency: 10
Reset counter: 255
Mileage: 109668 km
Time Indication: 0
Date: 2014.07.19
Time: 13:19:13
Freeze Frame:
RPM: 2800 /min
Load: 83.9 %
Speed: 124.0 km/h
Temperature: 98.0∞C
Temperature: 60.0∞C
Absolute Pres.: 990.0 mbar
Voltage: 13.335 V
008801 - Boost Pressure Control Valve (N249)
P2261 - 008 - Mechanical Malfunction
Freeze Frame:
Fault Status: 01101000
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 109687 km
Time Indication: 0
Date: 2014.07.19
Time: 13:42:58
Freeze Frame:
RPM: 3829 /min
Load: 9.4 %
Speed: 129.0 km/h
Temperature: 99.0∞C
Temperature: 84.0∞C
Voltage: 13.208 V
006435 - Please Check DTC Memory of ECU Number 2
P1923 - 008 -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 111065 km
Time Indication: 0
Date: 2014.08.04
Time: 20:00:13
Freeze Frame:
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Temperature: 84.0∞C
Temperature: 85.0∞C
Voltage: 11.811 V
Readiness: 0000 0000
Address 11: Engine II Labels: Redir Fail!
2 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 10
Reset counter: 255
Mileage: 109668 km
Time Indication: 0
Date: 2014.07.19
Time: 13:19:13
Freeze Frame:
RPM: 2802 /min
Load: 83.9 %
Speed: 123.0 km/h
Temperature: 98.0∞C
Temperature: 60.0∞C
Voltage: 13.208 V
012420 - Turbo/Super Charger Bypass Valve; Bank 2
P3084 - 008 - Mechanical Malfunction
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 109771 km
Time Indication: 0
Date: 2014.07.19
Time: 22:14:15
Freeze Frame:
RPM: 3535 /min
Load: 6.3 %
Speed: 89.0 km/h
Temperature: 96.0∞C
Temperature: 66.0∞C
Voltage: 13.462 V
