Page 1 of 2
Heavy Duty Control Arm kit??
Posted: Fri May 16, 2014 8:58 am
by vangelis
Hello, I've been looking around for a Reinforced Heavy Duty Control Arm kit for RS6 C6 but with no luck. I know some brands does this for most of the cars (ie MEYLE).
Anyone knows where to get one of this kits? or even in separate parts?
Re: Heavy Duty Control Arm kit??
Posted: Fri May 16, 2014 10:18 am
by C6NVS
I did a search here and found most of the suspension parts.
Is it the parts with the 'HD' extension you are looking for?
I suspect our RS6's share control arms and bushings from the A6 range.
Posted: Fri May 16, 2014 10:54 am
by vangelis
Here where? :) .. I'm looking for all the front suspension kit in heavy duty (reinforced). I found some kits on eBay and they showing compatibility for both A6 and RS6, but wondering if that's right as I can't imagine same RS6 control arms to be same in A6 2.0!!
Anyone can confirm that?
Posted: Fri May 16, 2014 11:12 am
by C6NVS
Posted: Fri May 16, 2014 11:56 am
by vangelis
Exactly.. But I can't buy items from this site.. I want to know where can I get them online!!
Posted: Fri May 16, 2014 1:32 pm
by C6NVS
If they are available here in the UK, and you are happy to cover costs, I would not object to placing an order on your behalf and sending them on.
Posted: Fri May 16, 2014 5:38 pm
by classba
C6NVS wrote:If they are available here in the UK, and you are happy to cover costs, I would not object to placing an order on your behalf and sending them on.
Very very nice man :biggrin3:
Posted: Fri May 16, 2014 8:38 pm
by vangelis
Very nice of you buddy :) .. I wish if you can, I just back from the UK and totally forgot about it. I'll check online about UK address and let you know :) thanks again :)
Posted: Fri May 16, 2014 8:42 pm
by vangelis
MEYLE UK Ltd., Burgess Hill
9–11 Consort Way
Victoria Business Park
Burgess Hill
West Sussex
RH15 9TJ
UK
Tel. +44 845 4506510
Fax +44 845 4506511
contact@meyle.co.uk
www.meyle.co.uk
Here's the contact details ... I want the full front kit and if there's multiple versions of any part I want the heavy duty/ reinforced version please. Would u mind to check and tell me what's the cost? I have PO box in UK also so shipping will be within UK only.
Posted: Mon May 19, 2014 2:15 pm
by Ric2001
http://www.ecstuning.com/Audi-C6_A6-Qua ... ntrol_Arm/
For the 4.2l engine, you would need to check that they fit the 5.0l monster.
Posted: Mon May 19, 2014 5:54 pm
by C6NVS
I will check and PM you.
Posted: Tue Dec 05, 2017 10:04 am
by Vieussuex*
Sorry to re-hash an old subject but I'm wondering if anyone can confirm if the Meyle HD kit for the C6 S6 will fit our RS6?
This is the the Meyle part number and link for the whole C6 S6 HD kit
Part no. 116 050 0095/HD
https://web2.carparts-cat.com/default.a ... 004&12=140
I've read conflicting info about our control arms sharing exactly the same part numbers all but for the one of the lower control arms.
Can you get away with running the Meyle HD part instead. Can anyone confirm?
The control arm in question..
Posted: Tue Dec 05, 2017 8:53 pm
by RossH14
i cheated and went polybush and IMHO the difference is rubber bush (not the ball joint or arm itself)
..StrongFlex and am very pleased with the car just feeling 'tighter'. but be warned changing everything is not a weekend job
viewtopic.php?f=47&t=118103&start=15
Posted: Tue Dec 19, 2017 4:28 am
by Vieussuex*
Tough job and well done for doing yourself RossH14!
If you don't mind sharing.. what were the part numbers for the Strongflex bushes for the lower arms?
I think the previous owner just changed the bushes and the arms are from factory. If you don't mind sharing.. what were the part numbers for the Strongflex bushes for the lower arms? ... then I can press in some polybush bushes for the new lower arms and also have brand new ball joints too.
Posted: Tue Dec 19, 2017 11:25 pm
by RossH14
if i have it right :
https://www.strongflex.eu/en/rs6-c6-04- ... 25182.html
part no 021773 and 021774
