Tailgate playing up
Posted: Sun Feb 02, 2014 8:27 pm
by Haggizbasher
I'm having issues with the power tail gate not opening all the way or closing all the way. The odd time it will close and locks with no problems. I've tried lifting the boot lid all the way up and pressing the close button for 4+ seconds.....it did close but has not worked properly since....... Has anyone had a similar problem....any suggestions.....thanks
Re: Tailgate playing up
Posted: Sun Feb 02, 2014 9:00 pm
by RS6chris!
Mine took a dizzy turn last week.
Wouldnt open of key fob but you could hear it lock clicking?
Basically had to force it up by hand and then close again my hand...three times then it seemed to rectify been ok since.
Mine has always stopped just short of fully open and I've had to push it up that last four inches or so.
Posted: Sun Feb 02, 2014 9:19 pm
by Haggizbasher
Mine will open with the key fob and switch in the car, but will only lift up 1 to 2ft. When I press the close button, nothing happens....keep pressing and sometimes it will close....but only half way
Posted: Sun Feb 02, 2014 11:21 pm
by gdavison
I'm in the no problems camp after 4 years of ownership ... what you guys doing ??
Posted: Mon Feb 03, 2014 12:20 am
by RS6chris!
Put the jinx on yourself now!!!!
Posted: Mon Feb 03, 2014 9:44 am
by R33
Have you tried to RTFM!? I had some issues and I had a little read of the handbook ad sorted out my woes! I can't remember how but I think the handbook explains how to set how far the boot opens too. Might be worth a look.............
Posted: Mon Feb 03, 2014 1:55 pm
by Haggizbasher
RTFM.... I like it... (i had to google that one...!!!) Still no joy though..... I fear the worst
Posted: Mon Feb 03, 2014 2:05 pm
by barryrs
Is this what they are getting at although the link is a Q5 -
http://www.youtube.com/watch?v=1Gqlo4Xyyfw
Has the memory on the power tailgate been set at a low height and can you simply re-program it as per the link?
Posted: Tue Feb 04, 2014 11:10 am
by R33
Haggizbasher wrote:RTFM.... I like it... (i had to google that one...!!!) Still no joy though..... I fear the worst
It's an acronym I've been using in the world of IT for many years, I meant it in the most polite way possible
Sorry it didn't fix the problem though.
Posted: Tue Feb 04, 2014 9:15 pm
by Haggizbasher
I love teasing the IT's at my work with it now...... Tailgate opens but switch for closing is dead.....does not work at all , need to force it close, however the locking mechanism works fine..... Might pull out the closing switch and have a look for any obvious signs
Posted: Fri Feb 14, 2014 6:56 pm
by Haggizbasher
Pulled out the switch, there was quite a lot of water in the void space.....looks like it was water damage. I've no idea how the water is getting in......I use a power washer to clean the car and I'm hoping that's how the waters is getting in... Changed out the switch for a new one and it works fine now....just need to sort out the water problem....!
Posted: Mon Feb 17, 2014 12:18 pm
by R33
Well done. Is it possible it's water leaking from the rear screen washer, this happened in my B7 S4 when the pump was on the way out? Have you smelt/tasted the water to see if it's fresh or washer fluid?
