Faulty rear LEDS?
Posted: Mon Oct 21, 2013 8:27 pm
by RS6chris!
My "outer" rear light cluster has suddenly gone very dim?
Any ideas guys?
I suppose it would be best to replace full unit??
Bad connection perhaps?
Trups???.....any ideas!
It one bloody thing after another recently with this car....starting to piss me off!!
Chris.
Re: Faulty rear LEDS?
Posted: Mon Oct 21, 2013 9:09 pm
by classba
Check your bulbs and make sure the connector is firmly pushed in place. If all are well, take the unit out and make sure the tracks are not corroded. Use WD40 to lub the tracks. Failing that then change the whole unit.
Posted: Mon Oct 21, 2013 9:13 pm
by RS6chris!
Do you speak from experience?
It's been really damp around my way last couple of days and absolutely pissed down over weekend?
I wonder if water has ingressed?
Posted: Mon Oct 21, 2013 10:21 pm
by classba
RS6chris! wrote:Do you speak from experience?
Not from experience Chris...Just some possibilities.
I've changed mine to the newer 2009+ version.
Posted: Tue Oct 22, 2013 8:25 am
by Trups
Chris.
if all LED's are dim then it could be a faulty resistor or something in the circuitry. Only way to repair them type of lamps is to split and then find the fault.
Will be easier and cheaper to buy a new lamp rather than try get someone to repair it.
Maybe upgrade like Classba to the newer lights?
Trups
Posted: Tue Oct 22, 2013 4:41 pm
by RS6chris!
Thanks lads.
Had unit to bits
Cleaned all connectors etc
No visible water or damp?
Just same after mucho phaffing about with wires WD40 etc
Looks like a new unit then... :audibash:
One thing after another recently!!!
Chris
Posted: Tue Oct 22, 2013 8:14 pm
by RS6chris!
Got your old ones for sale??
Posted: Tue Oct 22, 2013 9:13 pm
by classba
Sorry Chris, long gone.
Posted: Thu Oct 24, 2013 2:45 pm
by RS6chris!
New unit fitted all is well.
Can only put it down to faulty circuit board inside light unit?
Or damp?
New Valeo part(same as OEM) £130.
Posted: Thu Oct 31, 2013 2:15 pm
by Ric2001
What is the difference between the 2009+ edition lights on the avant?
Regards
Ric
