Page 1 of 4
MTM lowering springs.
Posted: Wed Jan 16, 2013 1:42 pm
by classba
Thinking of lowering the car a bit about 10-15mm all round so want to see if anyone has fitted the MTM kit. According to Kim@QST, he has fitted a number of them and all were happy with the result.
Thanks in advance.
Re: MTM lowering springs.
Posted: Wed Jan 16, 2013 5:10 pm
by RS6chris!
I'm also interested in this?
Any one?
Posted: Wed Jan 16, 2013 7:20 pm
by classba
Had a really long conversation with Kim about the pro's and con's and the way that the MTM springs ( KW) works in conjunction with the stock DRC. The springs are uprated in stiffness and are progressive coiled so the ride quality will not suffer much so long you don't go mad dropping the car to the ground. He recommends 15mm drop all round to give it that low ride look yet retain the stock dampers travel. With the slight lower stance you will induce a bit of negative camber which is a plus not only will sharpen your steering response, more clearance inside the arch and ultimately be more taught going round corners with the lower center gravity.
He also guaranteed that there won't be any rubbing if I don't drop the car more than 15mm even with my 22" wheels.
Fitting takes 5 hours to complete with the check of rear wheels geometry. The fronts have fixed points so no geometry checks are done. All four corners will be measured and leveled to the reduction ride height.
Posted: Wed Jan 16, 2013 7:58 pm
by RS6chris!
Instresting about the rubbing issue, my fronts rub slightly on speed bumps etc as I'm running 8mm spacers.
Any info whether you can run spacers with a drop?
Posted: Wed Jan 16, 2013 8:15 pm
by Mr V10
The KW (MTM) springs are 800 euros. Worth asking Grizz how much for the ones straight from KW, without the MTM branding. Probably cheaper and he supplies them. I'd be leaving the DRC alone if I had Audi warranty due to the DRC horror stories, ok, not so much on the C6 but still.
Posted: Wed Jan 16, 2013 9:25 pm
by bam_bam
classba wrote:...even with my 22" wheels.
:shock:
RULE 1.
/EDIT found 'em, are they the same as Bretto's?
Posted: Wed Jan 16, 2013 10:10 pm
by classba
Amar wrote:The KW (MTM) springs are 800 euros. Worth asking Grizz how much for the ones straight from KW, without the MTM branding. Probably cheaper and he supplies them. I'd be leaving the DRC alone if I had Audi warranty due to the DRC horror stories, ok, not so much on the C6 but still.
Even if they are slightly cheaper, I'll do more than the difference in petrol going to Grizz's.. :biggrin3:
:shock:
RULE 1.
Emmmmm, I've bought Bretto's car... :thumbs:
Posted: Wed Jan 16, 2013 10:25 pm
by classba
RS6chris! wrote:Instresting about the rubbing issue, my fronts rub slightly on speed bumps etc as I'm running 8mm spacers.
Chris, really surprised they rub at the front because the front is taller than the rear (check it out). Kim mentioned that there's a screw somewhere inside the front arch that can be removed to eliminate rubbing.
Posted: Thu Jan 17, 2013 6:24 pm
by RS6chris!
Yes there's a screw in the middle of the arch at the top?...didn't dare take it out on case something drops off!!!
Posted: Sat Jan 19, 2013 9:04 pm
by classba
Booked the car in with Kim next week if the weather permits... aiming to drop her by 25mm and go from there.
Can't bloody wait. :biggrin3:
Posted: Sun Jan 20, 2013 1:04 pm
by RS6chris!
classba wrote:Booked the car in with Kim next week if the weather permits... aiming to drop her by 25mm and go from there.
Rule one
Soon as!!!
Posted: Fri Jan 25, 2013 1:16 pm
by ollys
classba wrote:Had a really long conversation with Kim about the pro's and con's and the way that the MTM springs ( KW) works in conjunction with the stock DRC. The springs are uprated in stiffness and are progressive coiled so the ride quality will not suffer much so long you don't go mad dropping the car to the ground. He recommends 15mm drop all round to give it that low ride look yet retain the stock dampers travel. With the slight lower stance you will induce a bit of negative camber which is a plus not only will sharpen your steering response, more clearance inside the arch and ultimately be more taught going round corners with the lower center gravity.
Why are no geometry checks done at the front? I appreciate that camber at the front cannot be adjusted, but toe can be adjusted and the toe values will be affected by the drop in ride height so should be checked that they remain in tolerance and if necessary adjusted n my view....
Just FYI too - excessive negative camber is not a good thing to have if you want your tyres to last
Posted: Sat Jan 26, 2013 7:49 pm
by beefyblades
I'm running kw adjustable springs heard their similar to the mtm spring kit and 25mm drop will rub slightly on lock up front and slightly on the back too with couple of people on board or over speed bumps etc, mines about 23mm lower if I remember and still slight rubbing need to find this screw up front and lose it :lol: . That's on std 20's 5 spoke btw.
Posted: Sat Jan 26, 2013 8:06 pm
by classba
Beefy, MTM=KW they're the same. Thanks for the heads up. I'm on 22" so lets see how much I can lower without rubbing.
Do you find the springs much harder than stock and has the handling improved?,
Cheers fella. :beerchug:
Posted: Sat Jan 26, 2013 8:46 pm
by beefyblades
No worries chap, heard they were the same didn't know if mtm had there own spring rates or something though lol, and I find less body roll round faster motorway speeds sweeping corners, changes direction nicer at these speeds, still feel the weight of the nose in sharp 90 degree residential roads type corners but thats just shear inertia of the big girl I'd imagine ha ha, I'm in dynamic most the time anyway but still like to switch around with active suspension systems keeps em guessing, but ride comfort is excellent in my opinion too can't fault them really fella! Hope it helps, looks million times better too! :thumbs:
