Brakes
5.0 V10 50v biturbo - 571 bhp
P300
Re: Brakes
Post by P300 » Fri May 12, 2017 8:54 am
Also they are more likely to have the OEM's in stock. I tried to order discs and rear Ferodo pads from Euro's and they came back saying they couldn't get any of the parts and cancelled to order :(
A20LEE
Re: Brakes
Post by A20LEE » Fri May 12, 2017 12:34 pm
I've got my AP's going on next week.
grahamh84
Re: Brakes
Post by grahamh84 » Fri May 12, 2017 12:52 pm
Awe nice where did get those from ?
Sent from my iPhone using Tapatalk Pro
A20LEE
Re: Brakes
Post by A20LEE » Fri May 12, 2017 1:52 pm
Clark motorsport
longman h
Re: Brakes
Post by longman h » Fri May 12, 2017 2:11 pm
Were they around £950 for the front discs mate?
Daytona Grey C6 RS6 Avant
Ebony Black C5 RS6 Plus - Gone
longman h
Re: Brakes
And bells.
IanH755
Re: Brakes
Post by IanH755 » Fri May 12, 2017 2:15 pm
Be careful when replacing the hoses with Braided ones. The OEM ones rust like a git and can snap very easily causing you all manner of issues! MRC twice refused to do mine due to the corrosion on the OEM lines as they said they would need to drop the engine to replace the whole line due to the lack of space to carryout a repair, which isn't strictly true but shows you that if MRC baulk at doing the job it can be "interesting".
I found a local garage near Maidstone who had a "special tool" to reflange a broken pipe when there is only 4in of clearance available and they did mine without issue.
A20LEE
Re: Brakes
Post by A20LEE » Fri May 12, 2017 4:24 pm
Thanks for the heads up, I'll make sure they inspect them before starting. If not I'll get Grizz to do the hoses as he's doing the coolant pipes in two weeks. He can do those in 4 hours without removing the engine.
P300
Re: Brakes
Post by P300 » Fri May 12, 2017 6:25 pm
Got the discs and pads on this afternoon. It was a pleasant surprise how easy it was to do them all - it was a quicker job than they were on my old S4.
A20LEE
Re: Brakes
Post by A20LEE » Fri May 12, 2017 9:42 pm
That's what I was quoted but haggled a better price due to buying a full set
Studiowise
Re: Brakes
Post by Studiowise » Fri May 12, 2017 9:49 pm
Do share! (Or PM)
________________________________________________
RS6 C6 MTM Map Engine & Gearbox STAGE2
longman h
Re: Brakes
Post by longman h » Sat May 13, 2017 7:14 am
Thanks mate
P300
Re: Brakes
Post by P300 » Sun May 14, 2017 3:36 pm
Everything has worked out nicely with the change and already the feel is better than the original set up with the Ferodo pads. Thanks for all the advice.
Still getting used to the car. Standard brake performance is still better than my old B8 S4 but you can feel the extra weight of the car. It's a heavy old beastie!
IanH755
Re: Brakes
Post by IanH755 » Mon May 15, 2017 4:39 pm
The "best" bit is that you can now repeatedly stamp on the anchors with minimal fade compared to OEM and when it eventually does start to fade (can't beat the laws of friction) it's a much better pedal feel so you still know exactly how much pedal you've got left before you get to squeaky bum time :D
C_J
Re: Brakes
Post by C_J » Tue May 16, 2017 9:28 am
Do they do a plain option or drilled option?? I'm not a fan of grooved discs.
S4 b5 340bhp
Rs4 b5 507bhp
Rs6 c6 project 800bhp
S3 stock daily work hack
Users browsing this forum: No registered users and 111 guests
