Have just purchased a new (to me) Audi C6 RS6, and am confused as to what MMI version I have due to conflicting google results. Main aim of knowing is whether I can plug and play a Bluetooth adapter (3G) or need to do a bit more intensive installation (2G).
According to my MMI setup, my SW version is C6-HU, which sounds like a 2G High version, however, I also have a joystick as part of my centre console selector, which apparently is a 3G offering.
I have the AMI plug in my glovebox in a little hideaway drawer, as opposed to the roof of the glovebox as others I've seen.
So, does anyone have anything definitive that they can offer as insight?
Plus a pic as thanks!
Confusion about MMI version for my new (to me) C6
Re: Confusion about MMI version for my new (to me) C6
Hi and welcome!
Do you need/want the hands-free or just the benefit of playing music from the mobile ?
I needed it only for music and got the one below, just plug & play in the AMI, however you might need to give us a VIN so we can check what's on the car, unless someone upgraded it along the way...
https://www.amazon.se/dp/B07JPYGWVG/ref ... _item?th=1
/Alex R
/Alex R
Thanks Alex, I purchased a Tune2Air adapter off FB Marketplace as a little It's only $10 so what's the risk and it worked exactly as I thought it would, which is fantastic - just plugs straight into the AMI input and viola.
Speaking of the VIN though, I've never been able to find the build sheet for this car, even asking my local Audi dealership and the silence was deafening - is this something you could help with?!? If so, WUAZZZ4F58N902161
As I see it it's a MMI 2G High... and below you have the part numbers that are on your car.
8T0 919 603 C Displayenhet för Multimediainterface 'MMI' 'HIGH'
4F1 910 732 B interfacebox med mjukvara F 4F-8-901 251>> höger fram
I've attached the pdf with the PR's
Sorry for the Swedish, seems that I can't change the language.
/Alex
/Alex
- Attachments
- WUAZZZ4F58N902161.pdf
- (101.6 KiB) Downloaded 38 times
I will work on my Swedish (or Google translate), but thank you so much for this!
No problem mate! Have a good one!
Users browsing this forum: No registered users and 39 guests
