RS6 Headlamp & tail lamps required.
5.0 V10 50v biturbo - 571 bhp
SamC_86
Post by SamC_86 » Thu Jan 09, 2025 3:34 am
Hi All,
Does anybody have a spare offside front headlamp and/or complete set of tail lamps available? I need them to get my car through its MOT. The O/S headlamp is flickering and the tester has taken issue with the tinted rear lamps that have been in situ 5+ years.
The tail lamps I know you can get online for about £600 for a set but having just lost my job and also having to put a tyre & drc shock on the car, the bill is climbing.
Headlights seem to be like hens teeth. Very hard to come by. Audi had 1 available but at over £1700+ fitting I thought I'd check here first.
Any help would be greatly appreciated.
Audi_Fanatic
Re: RS6 Headlamp & tail lamps required.
Post by Audi_Fanatic » Thu Jan 09, 2025 4:29 am
Have you considered a bulb change for the flickering headlamp? That is symptom of failing bulb. Switch the bulbs from the left and right side and see if the flickering follows the bulb or stays with the headlamp. Then you know its the bulb or the ballast. Replace as needed. It seems a bit silly to purchase an entire headlamp to solve this problem as that is the most expensive option.
As for the rears, can you just peel the tint off the rear lights? Watch a video on YouTube to see how it's done.
SamC_86
Post by SamC_86 » Thu Jan 09, 2025 11:21 am
Hi Audi Fanatic. An alternative bulb has been tried, same issue. I am going to investigate ballast replacement.
We've examined the rear lights closely. It doesn't appear to be a film tint. We have tried using white spirit and also brake cleaner to remove the tint thinking it may have been chemical/spray on. It didn't budge, I suspect they are aftermarket lamps that were manufactured that way.
Limited100
Post by Limited100 » Sun Feb 02, 2025 9:06 pm
I've got a spare set of rear lights in good condition, feel free to DM to discuss.
C6 RS6 Avant 2009 | Stock turbos | Wagner ICs | BMC filters | Secondary cats removed
Currently an unknown stage 1 map, making 658 bhp 805 NM on a hot day on Tesco 99, laggy but no boost leaks
Will not go to stage 2 confirmed by MRC because turbos already at 9x% duty, a mystery - engine out to diagnose
Runs fine for now, done 10k miles in it in 10 months, perhaps in the next couple of years will refurb turbos etc.
1000 bhp not viable because gearbox upgrade alone is £9k
Explore Audi wall art
Users browsing this forum: Quinten and 48 guests
