8 Speed ZF8hp from C7 RS7 and RS6 retrofit.
5.0 V10 50v biturbo - 571 bhp
VaudiGR
Re: 8 Speed ZF8hp from C7 RS7 and RS6 retrofit.
Post by VaudiGR » Sun Jun 25, 2023 3:36 pm
welwynnick wrote:Hi there, I'm on holiday at the moment, so don't have everything to hand, but from memory - yes to everything.
Nick
Are you back? Let's get this ball rolling!
Sent from my SM-S918B using Tapatalk
welwynnick
Post by welwynnick » Mon Jun 26, 2023 6:22 pm
Yes, the Bentley Continental GT and Silver Spur definitely use the ZF 8HP90A74 transmission.
Both 4.0 and 6.0 engines use that gearbox, though the torque converters are different
It was used on facelift mark one models built between 2012 and 2017. Earlier cars used the 6HP26 like the RS6, and later cars use the dual clutch transmission.
Nick
VaudiGR
Post by VaudiGR » Mon Jun 26, 2023 8:05 pm
welwynnick wrote:Yes, the Bentley Continental GT and Silver Spur definitely use the ZF 8HP90A74 transmission.
Nick
So a zf8 from a bentley 4.0 would bolt on?
I have the means to get a complete kit, to proceed with a project that would involve fitment and electronics. However people here in Greece tell me they require a working 4.0 bentley with such transmission in order to connect and read the tcu and compare to the rs6 c6 to be able to make a seemless connection of the 2 gearboxes.
Unfortunately not a lot of bentleys are around in Greece to use as a read vehicle.
Anyone that could help?
welwynnick
Post by welwynnick » Tue Jun 27, 2023 9:53 am
The ZF 8HP90A74 plus adapter isn't EXACTLY a bolt on, but it's close. There are a couple of minor fouls on the bell housing adapter, though they really are minor. The transmission rear mounting is different and might have to be fabricated.
welwynnick
Post by welwynnick » Tue Jun 27, 2023 9:55 am
I'm impressed that you've got some people who are willing to take this on, though. I don't think this is something that forms part of anyone's job description.
VaudiGR
Post by VaudiGR » Tue Jun 27, 2023 10:37 am
welwynnick wrote:I'm impressed that you've got some people who are willing to take this on, though. I don't think this is something that forms part of anyone's job description.
It's intriguing that the best gearbox could be matched to the best audi engine, that's why I'm pursuing it.
Also from what I'm told as both boxes are can-bus, once they are properly 'read' then there shouldn't be much of an issue to make them work.
I am aware that the propshaft is different, however the rear diff appears externally at least similar. In Greece a complete propshaft can be built to suit, although I'm not sure that would be needed.
To a certain degree I'm willing to be the guinea-pig here so long as there is valid evidence that can be done. This then could be an alternative for an upgrade for those aiming for 1000hp.
Please email me for details
vasilis3690@gmail.com
VaudiGR
Post by VaudiGR » Sat Jan 06, 2024 2:11 pm
Any update here? Trying to keep this alive!
welwynnick
Post by welwynnick » Sat Jan 06, 2024 3:37 pm
I've been looking for other cars that have replaced the 6HP with the 8HP, and there are several instances, but they've typically used an aftermarket transmission control unit, which is disappointing.
https://www.youtube.com/watch?v=n5hSrXZ18cA
https://turbolamik.eu/
More gratifyingly, a few highly tuned Nissan Skylines with high power, torque and max revs, use the 8HP, and the 'box seems to hold up. 1,100 HP and 9,000 RPM!
https://www.youtube.com/watch?v=2aIHGkYRH0c
This guy did a V8 + 8HP swap into an S5, so worth watching:
https://www.youtube.com/@Svarogperformance/videos
Nick
VaudiGR
Post by VaudiGR » Sat Jan 06, 2024 7:01 pm
I have emailed turbolamik today about this as I have reached a dead end regarding using OEM tcu. In order to check if there is a chance of getting them to work we need a working bentley car and a working rs6 to read them with odis and download all relative info. Unfortunately I don't have a bentley here in Greece and even after contacting Ricky (REperformance) via a friend I was let to believe its not an easy task to match those 2 up.
audiautist
Post by audiautist » Mon Jun 09, 2025 2:50 pm
Hey, love being a necromancer with these obscure forums, and thank you to @welwynnick for doing all of this intro research.
Just to confirm, you all are using the bently adapter to bolt the bently 8hp90 onto the c6 s6 v10 5.2L (the 2004'?' - 2011) version correct?
I have no use for an OEM controller and will happily use the turbolamik setup, I just need the 2 compoennts to physically connect to eachother more so than I need it to be controlled by anything factory.
Looking forward to hearing back, and thank you all for the research you have done so far!
welwynnick
Post by welwynnick » Mon Jun 09, 2025 3:09 pm
Just to confirm, you all are using the bentley adapter to bolt the bentley 8hp90 onto the c6 s6 v10 5.2L (the 2004'?' - 2011) version correct?
Yes to the first part. However my interest is with the C6 RS6 5.0 V10 engine, and not the S6 5.2 V10.
There are many similarities between them, including that they both have block girdles.
However there are some significant differences as well, including the RS6 being dry-sumped.
Whether that makes any difference to the ability to fit an 8HP90 I couldn't be sure.
Since they both fit the 6HP26, I guess the 8HP would still fit, but you would need to look hard and look close.
