What arch liner fixings?
5.0 V10 50v biturbo - 571 bhp
Doug_RS6
Post by Doug_RS6 » Tue Sep 20, 2022 8:04 pm
Can someone confirm what the 3 fixings that go at the bottom front edge of the arch liners look like?
Jim Haseltine
Re: What arch liner fixings?
Post by Jim Haseltine » Wed Sep 21, 2022 8:24 am
The ones that join the arch liner to the belly panel?
Example pic: https://www.amazon.com/Rexka-Splash-Ret ... B07CKCXY39
If you need some I wouldn't advise buying them from there, they're available much cheaper.
Doug_RS6
Post by Doug_RS6 » Wed Sep 21, 2022 6:02 pm
That fits on the inner two but there are more layers on the outer one so doesn't seem long enough.
Jim Haseltine
Post by Jim Haseltine » Thu Sep 22, 2022 12:24 am
It's tight but they do fit the others. It's best to fit the other ones first so that you can move the belly panel around a bit to turn the fittings.
Doug_RS6
Post by Doug_RS6 » Thu Sep 22, 2022 4:44 pm
I'll try again but it just snaps the fittings as they aren't pushed in far enough to turn and latch.
Jim Haseltine
Post by Jim Haseltine » Fri Sep 23, 2022 10:56 am
The only one I had difficulty with on my car was the right outer which had a habit of pushing the socket out of the bumper mount - refitting that was a PITA until I super-glued it in place. Prior to that I resorted to trimming the back of the arrowhead which effectively made the shaft of the fitting about 2-3mm longer. An untrimmed item won't turn. I'm pretty certain that there's an untrimmed one in place now but I can't get it out to check because it's too tight to be removed without the elbow room afforded by taking the wheel off.
ATinOf
Post by ATinOf » Sun Oct 16, 2022 7:46 pm
I dont have belly panels, Ive threatened on multiple occasions to sort out new bottom panels and wheel arch liners but ive always postponed it as I know its going to be an expensive job, Id need a full suite and all the fixings - its never had bottom covers since Ive owned it
Jim Haseltine
Post by Jim Haseltine » Mon Oct 17, 2022 8:19 am
Even though they're fixed properly, the ones on my that run the length of the sills rattle like, er, well, things that rattle a lot. I'm tempted to pad them with some strategically placed pieces of closed-cell foam.
Users browsing this forum: slant and 45 guests
