C6 RS6 get you home wheel
5.0 V10 50v biturbo - 571 bhp
WooshNI
Post by WooshNI » Sun Aug 09, 2020 9:18 am
Hi everyone I am looking information about the above does anyone know exactly what and where to get a slim line wheel for a C6 RS6
I understand apparently if I can find one it will only fit the rear as the front calipers are too big so a front flat requires changing 2 wheels if u see what I mean.
Thanks for any info
drybeer
Re: C6 RS6 get you home wheel
Post by drybeer » Sun Aug 09, 2020 12:38 pm
I’m sure someone is selling one in the parts section?
C7 A6 allroad 3.0TDi.
Tiguan 2.0TDi R-line
Jim Haseltine
Post by Jim Haseltine » Sun Aug 09, 2020 1:29 pm
The one advertised in the parts section is the same sort as I got hold of for my car. It fits over the front calipers no problem - although you shouldn't fit a space saver on the front axle - and it fits in the wheel well no problem. The only issue is finding somewhere to store the insert that holds the pump & foam. You need some sort of pump - don't know if the one for the foam will work - and inflate the thing before the weight of the car goes on it. Inflated it's almost exactly the same diameter as a slightly worn 275/30 20" tyre.
It's an option for the C7 Allroad, current Audi part number is 4G0601010C (I think). There is an alloy version (can't remember what car it was for), very rare second hand and VERY expensive.
WooshNI
Post by WooshNI » Sun Aug 09, 2020 3:35 pm
how do i find the parts section thanks
