Cheers Jim.Jim Haseltine wrote: ↑Mon Feb 24, 2020 7:05 pmHow long? Awkward question. There are a number of factors to take into account, not the least being that I was taking my time, was working outside with little space and the car on stands. I have about 3' between the front of the car and a wall, similar distance behind it to another wall and the same (at best) to the right where there's another car. It's only to the left of the car where I've got unrestricted access. Lifting gear was a decent trolley jack (3 ton I think) and an engine crane. I also had to knock off from time to time so I could source tools which I didn't have. And then there were things like having to cut off the exhaust sleeves and dealing with a difficult positioned bolt that I'd stripped. Ignoring breaks and other times when I wasn't actually working (neighbours do insist on talking) I'd say it was over 30 hours spread over a week and a half, maybe two, to get the engine out. Working inside with space to move, a post lift, all the tools to hand, an assistant when needed AND having done the job once already, I could take at least 10 hours off that, maybe even half it.
But that's taking it out and remember, although the engine was free, I never moved it away from the car, I just slid it back, lifted it and bolted the mounts into place after I'd taken the manifolds off then dropped it again later to refit them but I also removed other things (like the oil tank so it could be repainted) which don't need to be touched if you're just dropping the engine. Putting it all back in place properly took at least as long as taking it out - and that was before I got around to filling the fluids.
Still contemplating on the idea is it worth doing this job or not!?
Other than an oil seal, is it worth tackling other jobs when the engine is out?
