C6 RS6 Exhaust valve mods
Thinking of soon buying a C6 and wanted to get an aftermarket exhaust but am worried about hassle from neighbours do any of the aftermarket systems have the valves fitted so it can be set to quiet on cold start in the winter months ?
MTM did an exhaust which had valves on it I believe look on the QST website.
Demand Engineering and Fourie Fabrications could build you an exhaust to your requirements taking into consideration noise levels. They would be the two I would approach if I was doing another C6 exhaust. Or you could get an off the shelf system such as SuperSprint.
Volvo XC90
C7 - RS6
C6 - RS6
B5 - RS4
C7 - RS6
C6 - RS6
B5 - RS4
Re: C6 RS6 Exhaust valve mods
rtd wrote: ↑Sun Jan 14, 2018 1:53 pmMTM did an exhaust which had valves on it I believe look on the QST website.
Demand Engineering and Fourie Fabrications could build you an exhaust to your requirements taking into consideration levels. They would be the two I would approach if I was doing another C6 exhaust. Or you could get an off the shelf system such as SuperSprint.
Many thanks will look into it
I have a MTM valved exhaust fitted to mine, with the valve being wired into the rear blind switch on the centre console. Cold start is great for waking the neighbours (but can be turned off). On full chat with valves open the sound is awesome, especially on up-shifts and throttle blipping down the box is pure music
Long autobahn/motorway cruises with valves closed - slightly louder than standard but no droning either.
Great exhaust system but not the cheapest either.
I have a remote controlled valve fitted on a standard exhaust (came with the car). If you're in the Bedford area you'd be welcome to come and inspect/listen and see if it's for you. Drop me a PM if you're interested.
Just to add to the options, Demand Engineering custom fabbed a valved system of me. Sounds ace and pops/crackles even louder now
https://photos.app.goo.gl/BYkRjXMj3Y2pKr9XA
https://photos.app.goo.gl/dSqxbxMWVxffdrUs9
2008 Daytona Grey RS6 - Secondary Decat MRC Stage 2 Map
1989 Jaguar XJR Janspeed 3.6 Bi-Turbo
2016 Triumph Tiger800 XCA
