Replacement brake discs
5.0 V10 50v biturbo - 571 bhp
IanH755
Re: Replacement brake discs
Post by IanH755 » Mon Sep 04, 2017 11:28 pm
Plus AP's are a massive 8kg lighter per disc, better cooled & made from better grade of steel, all of which makes for much better performance vs OEM.
***NEW*** Daytona C6 RS6 Avant - MRC'd - 955HP & 1200NM (PistonHeads Link)
Farravi
Post by Farravi » Tue Sep 05, 2017 7:57 am
On a slight tangent, my ceramics squeal alot, any idea how to stop that? @Ian
wireliner
Post by wireliner » Fri Oct 27, 2017 4:52 pm
Hi guys,
Following advices, I ordered AP discs.
Just received today :wink:
Just need to assembly and then install them.
CHEQUERED
Post by CHEQUERED » Tue Oct 31, 2017 2:52 pm
Can someone confirm the front and rear part numbers please (non ceramic)
CP8080Z24CG12 & 25CG12 Front
bells CP8080Z240 front
CP8080Z26CG12 & 27CG12 Rear
bells CP8080Z260 rear
IanH755
Post by IanH755 » Tue Oct 31, 2017 3:37 pm
From the AP Racing website -
Fronts - https://www.apracing.com/product_detail ... _2010.aspx
RH Disc = CP8080Z24CG12
LH Disc = CP8080Z25CG12
RH/LH Bells = CP8080Z240.
Rears - https://www.apracing.com/product_detail ... _2010.aspx
RH Disc = CP8080Z26CG12
LH Disc = CP8080Z27CG12
RH/LH Bells = CP8080Z260.
wireliner
Post by wireliner » Fri Nov 10, 2017 3:25 pm
Plus AP's are a massive 8kg lighter per disc, vs OEM.
IanH755, I don't know where you took information but let me show you the real weight:
Ap racing :
OEM double sens:
8kg :shock:
the difference is only 618gr per side : so almost 5% less...which is better than nothing.
IanH755
Post by IanH755 » Fri Nov 10, 2017 6:04 pm
I think I've been on crack :D
I weighed mine on my works scales (I only had small kitchen scales at home) and I got the AP's at 12Kg and OEM at 16.5Kg so I think the wildly wrong 8kg per disc came from adding both sides, however neither figures are the same as what you've got which is confusing me.
Could you try standing the discs upright rather than laid down incase there's a difference (thats how I did it)? The reason I ask is that ,if you lift both, do you think both weigh virtually the same, as per the scale results, as I felt the AP disc setup with the hat included still felt lighter than the OEM.
I also know myself and TomRS have weighed our 410mmx36mm discs and both got 13.5kg, so I can't imagine 390mm discs only being 300g lighter than 410mm discs?
wireliner
Post by wireliner » Fri Nov 10, 2017 6:39 pm
I will try your solution, no pb:
I also has the different parts separately:
Jim Haseltine
Post by Jim Haseltine » Fri Nov 10, 2017 7:00 pm
The weight of the used OE discs will depend on the level of wear but I doubt that even mine have lost 2.5Kg each.
Still, it'd be interesting to try weighing mine when I do the job.
wireliner
Post by wireliner » Fri Nov 10, 2017 7:06 pm
Discs were not that bad,
I double checked the weight:
Jim Haseltine
Post by Jim Haseltine » Sat Nov 11, 2017 11:25 am
MoT time today, so whilst the car was in I asked my Steve to measure the front discs ('cos I forgot to do so last week when I changed the pads). They aren't as bad as I'd assumed, they've still got 0.5mm before they reach the limit.
Usually he has a list of things he could have a go at me about (which last year included the coolant pipes, 'the' oil leak and some brake line corrosion), but all he could say was that the driver's door lower hinge could do with some lubrication.
IanH755
Post by IanH755 » Sat Nov 11, 2017 7:59 pm
Wireliner - Thanks for the update, looks like my work scales are wrong then but it's good to get confirmation on the correct weights, thanks.
wireliner
Post by wireliner » Sun Nov 12, 2017 10:51 pm
You're welcome. :beerchug:
CHEQUERED
Post by CHEQUERED » Thu Nov 16, 2017 4:45 am
No one locally (Australia) has these in stock, where have you guys found the best place to order them? Cheers Trent
wireliner
Post by wireliner » Wed Nov 29, 2017 9:24 am
