Replacement brake discs
Re: Replacement brake discs
Plus AP's are a massive 8kg lighter per disc, better cooled & made from better grade of steel, all of which makes for much better performance vs OEM.
On a slight tangent, my ceramics squeal alot, any idea how to stop that? @Ian
Hi guys,
Following advices, I ordered AP discs.
Just received today
Just need to assembly and then install them.
Just received today
Can someone confirm the front and rear part numbers please (non ceramic)
CP8080Z24CG12 & 25CG12 Front
bells CP8080Z240 front
CP8080Z26CG12 & 27CG12 Rear
bells CP8080Z260 rear
From the AP Racing website -
Fronts - https://www.apracing.com/product_detail ... _2010.aspx
RH Disc = CP8080Z24CG12
LH Disc = CP8080Z25CG12
RH/LH Bells = CP8080Z240.
Rears - https://www.apracing.com/product_detail ... _2010.aspx
RH Disc = CP8080Z26CG12
LH Disc = CP8080Z27CG12
RH/LH Bells = CP8080Z260.
I think I've been on crack
I weighed mine on my works scales (I only had small kitchen scales at home) and I got the AP's at 12Kg and OEM at 16.5Kg so I think the wildly wrong 8kg per disc came from adding both sides, however neither figures are the same as what you've got which is confusing me.
Could you try standing the discs upright rather than laid down incase there's a difference (thats how I did it)? The reason I ask is that ,if you lift both, do you think both weigh virtually the same, as per the scale results, as I felt the AP disc setup with the hat included still felt lighter than the OEM.
I also know myself and TomRS have weighed our 410mmx36mm discs and both got 13.5kg, so I can't imagine 390mm discs only being 300g lighter than 410mm discs?
I will try your solution, no pb:
I also has the different parts separately:
The weight of the used OE discs will depend on the level of wear but I doubt that even mine have lost 2.5Kg each.
Still, it'd be interesting to try weighing mine when I do the job.
Discs were not that bad,
I double checked the weight:
MoT time today, so whilst the car was in I asked my Steve to measure the front discs ('cos I forgot to do so last week when I changed the pads). They aren't as bad as I'd assumed, they've still got 0.5mm before they reach the limit.
Usually he has a list of things he could have a go at me about (which last year included the coolant pipes, 'the' oil leak and some brake line corrosion), but all he could say was that the driver's door lower hinge could do with some lubrication.
Wireliner - Thanks for the update, looks like my work scales are wrong then but it's good to get confirmation on the correct weights, thanks.
You're welcome.
No one locally (Australia) has these in stock, where have you guys found the best place to order them? Cheers Trent
Users browsing this forum: No registered users and 36 guests
