Tune2air device
5.0 V10 50v biturbo - 571 bhp
Pgj0hns0n
Tune2air device
Post by Pgj0hns0n » Mon Sep 18, 2017 8:04 pm
I've seen various threads on using these devices but it's not flashing blue when I connect it via the adapter cable.
Just updated the MMI to 5570 but it's still. It working. It's driving me bonkers as I stream everything.
Any help from anyone else whose encountered similar problems would be appreciated.
Paul
Jess
Re: Tune2air device
Post by Jess » Thu Sep 21, 2017 9:21 am
Hi Paul,
We use this cable, sometimes it takes a few minutes to show up on the media options screen. Once I had to disconnect and reconnect it. Always flashes however. Not sure what your problem is though.
Rs6c6NI
Re: Tune2air device
Post by Rs6c6NI » Thu Sep 21, 2017 10:53 am
I tried it, everything you have done, apparently some cars it just doesn't work on. I sent mine back to amazon and got a refund.
Pgj0hns0n
Re: Tune2air device
Post by Pgj0hns0n » Thu Sep 21, 2017 10:57 am
One thing I've noticed is some of the wma3000a models have a USB-c port as well as the adapter lead. The version I have has the USB-c port but I've just ordered one that doesn't have the USB port. Not sure if there's a difference. I'll let you know if there's any change
ronaldmacdonald2017
Re: Tune2air device
Post by ronaldmacdonald2017 » Thu Sep 21, 2017 8:05 pm
Daft question - but have you got it pushed in / connected fully?
Pgj0hns0n
Re: Tune2air device
Post by Pgj0hns0n » Thu Sep 21, 2017 8:23 pm
Fair question but if I press any harder I'll push the socket in plug into through the housing lol
Pgj0hns0n
Re: Tune2air device
Post by Pgj0hns0n » Sun Sep 24, 2017 1:43 pm
Update - got Bluetooth working!!!! So here’s what I tried that got me to a successful Bluetooth connection:
- upgraded MMI to 5570
- tried wma3000a tune2air (with Audi adapter joined to it) - didn’t work
- tried a genuine 30pin Audi adapter to an old iPhone 5 - able to stream music through the MMI
- purchased BOVEE wma1000 Bluetooth adapter
- connects wma1000 to 30pin adapter lead - success!
Bluetooth started to flash - iphone7 instantly connected to the device - now can stream to MMI!
RESULT
SteveG
Re: Tune2air device
Post by SteveG » Sun Sep 24, 2017 9:35 pm
The cable connection I have does not flash. It stays lit blue all the time. Works fine.
Pgj0hns0n
Re: Tune2air device
Post by Pgj0hns0n » Mon Sep 25, 2017 5:16 am
Yes I should have also said once paired the light stays on blue.
MNK
Re: Tune2air device
Post by MNK » Mon Sep 25, 2017 8:49 am
On my old 2010 RS6 I used AMI to Apple 30-pin lead (some £10 one off Amazon, not OEM), then Tune2Air, worked perfectly every time
Pgj0hns0n
Re: Tune2air device
Post by Pgj0hns0n » Mon Sep 25, 2017 9:24 am
Yep, exactly the same
Users browsing this forum: IanH755 and 64 guests
