Suspension arm bushes
Re: Suspension arm bushes
MRC said they fit but the rubber compound was softer than OEM so I went with Lemforder in the end.
***NEW*** Daytona C6 RS6 Avant - MRC'd - 955HP & 1200NM (PistonHeads Link)
some advice - anyone have a trick' to get the rear bottom bush into place??
RS6 V10 Sepang Blue Avant
VW T5 4 motion
Lotus Exige GT3
VW T5 4 motion
Lotus Exige GT3
A cleaned up hole with lots of lube usually gets me into the bottom bush
BamBam style jokes aside, if the hole is cleaned up and lubed slightly would a C-clamp have enough force/torque to press the bush?
A decent quality screw drive hose clip to compress the end of bush often helps. And as mentioned, lubrication.
yep - lots of soapy water - start at and angle then 'flip it in' worked.... now to get the rest of it all back together
VW T5 4 motion
Lotus Exige GT3
VW T5 4 motion
Lotus Exige GT3
moving fwd - rear end assembled - now a break as i'm off sailing (Fastnet race), before sorting front
VW T5 4 motion
Lotus Exige GT3
VW T5 4 motion
Lotus Exige GT3
I'm really sorry but to me that combination of colours makes it look like you've fitted a kit from the Early Learning Centre.
yep - i am that big a child, as they say our toys just get more expensive
VW T5 4 motion
Lotus Exige GT3
VW T5 4 motion
Lotus Exige GT3
the ELC suspension is now complete
- having the alignment checked. but car feels much more taught.
DIY fitting is not for the faint hearted but IMHO a definite improvement over the rubber bushes
VW T5 4 motion
Lotus Exige GT3
VW T5 4 motion
Lotus Exige GT3
Congrats dude, thats a lot of work you've done!
I wish I had the facility to do all that at my place - that's a big old job! I'm still waiting to get time to get the ARB's on. Good work.
Guys i need help please. I need to change tie rods outer left and right. Any suggestions? It is not easyyyy. Im all the way in malaysia. As long as its affordable, dont really mind the oe quality. Cant even do alignment due to jammed nut. Please help
RS6 C6 SEDAN RHD VS_PERFORMANCE STAGE 1.5, 2ND CAT DELETE, MILTEK CATBACK, BMC DROP IN FILTERS.
IanH755 wrote: ↑Mon Dec 21, 2015 11:34 amJust bought a full front Meyle HD kit from eBay for around £330.
There are two bits which are supposed to be RS6 specific (track-rod ends and rear lower arm) however the two Meyle replacement parts in the kit are NOT RS6 specific and you can't buy the specific parts from Meyle as they don't stock them.
Just to take the mick, Audi want over £400 for the two track-rods and 2 rear lower arms and the whole "kit" would be about £1300 vs Meyles £330!
So did it work? The tie rods fit good?
IIRC I bought the Audi (lemforder OEM) parts as I believe (maybe wrong) that although the Meyle parts do fit the rubber used is of a lesser strength/rating compared to the Audi parts, which would make sense as those Meyle parts are the same number for A6 to RS6.
However that was over 2 and half years ago so I've no idea what the kit currently has or the spec of the materials in it.
Ok do u have a link for it so i can just buy it now please?IanH755 wrote: ↑Sat May 19, 2018 8:01 pmIIRC I bought the Audi (lemforder OEM) parts as I believe (maybe wrong) that although the Meyle parts do fit the rubber used is of a lesser strength/rating compared to the Audi parts, which would make sense as those Meyle parts are the same number for A6 to RS6.
I dont mind if its not as good as oem but as long as it fits then its superb
