small knock
small knock
hello
I am getting a small knock which I think is from the prop shaft under hard acceleration. anyone else had the same problem or suggestions ?
cheers
cheers
Re: small knock
It might be a bush somewhere else on the car unless you've identified it to be in the centre of the car.
How many miles has the car got?
Daytona Grey C6 RS6 Avant
Ebony Black C5 RS6 Plus - Gone
Re: small knock
69k and it sounds like a rotating thump from under centre of rear floor
Re: small knock
Failed propshaft bearing. Common with these.
Re: small knock
Yay my video!
It only takes about 10 sec to get under the car and confirm it's this bush (about 1/2 way along the prop-shaft). "Officially" the only fix is a replacement prop-shaft at £1K+ (think was near £1200 but can't recall) which if you have a Warranty is fine but any prop-shaft company can fix it once it's off the car for much less. It needs rebalancing it once it's back together which is why I recommend a company do it or if you're a nutter you can buy the rubber-bush separately (One on eBay here etc) strip the propshaft apart and rebalance it yourself during the rebuild.
***OR*** - You could talk to these lovely people who, if they are still making car propshafts, will charge you a pretty penny but you "should" be left with something extremely unique (not that I've looked at all and found they're on MRC's doorstep and owned by an aerospace company I deal with almost daily etc.............honest!)
Re: small knock
Same with the Ur-quattro. "New propshaft", whereas there's a BMW bearing which is identical for around £50.IanH755 wrote: ↑Sun Jun 11, 2017 6:48 pm"Officially" the only fix is a replacement prop-shaft at £1K+ (think was near £1200 but can't recall) which if you have a Warranty is fine but any prop-shaft company can fix it once it's off the car for much less. It needs rebalancing it once it's back together which is why I recommend a company do it or if you're a nutter you can buy the rubber-bush separately
Re: small knock
Found my car to have the same issue. Slight vibration under hard acceleration, from near the centre of the car. Mine looks slightly worn, but nowhere near as bad as above video. I will be looking to fix the issue in the next month or two.
Re: small knock
In the video the seal had completely disintegrated a full 360' around the bearing so there was a 1cm air gap between the bearing and the outer metal with no rubber between the two
Re: small knock
had mine on ramp and mine centre carrier is shot like the video , got bearing sorted from ebay and doing it next Saturday
Re: small knock
mine all done now , was not too bad of a job the worst part was taking the exhaust off
Re: small knock
What about the rebalancing??
Re: small knock
mot needed as put back together as it came off
Re: small knock
Good to know, its manageable.. cure your issue..??
Re: small knock
oh yes you can do it without taking it off from the gearbox end just split shaft after damaged carrier bearing and it sorted the knock out on mine
Re: small knock
How do you split the shaft in the centre..?? I have mine of and can't split it at all..??
Users browsing this forum: IanH755 and 62 guests
