What winter tyres do you have?
5.0 V10 50v biturbo - 571 bhp
lostandfound
Post by lostandfound » Thu Nov 03, 2016 12:09 am
Hi first time post here on rs246...
So it's getting a bit cold and this is my first winter with my C6. I'm driving down to the Alps in December (please don't try to guess how much fuel that'll be!) and the PZeros are running a bit low. Looking to swap out all 4 for a set of winters (see fuel comment above). What should I get? I can see a few of you on this forum use winters but I can't find much in terms of which ones you use and how they preform?
Best guess right now is Pirelli sottozero or Dunlop 3d, I have no experience of either!
Open to suggestions, what do you use and would you recommend them?
Cheers!
HPsauce
Re: What winter tyres do you have?
Post by HPsauce » Thu Nov 03, 2016 12:20 am
Pirelli Sottozeros here, to be precise the no longer available Winter 240 Serie II, standard (not runflat).
Asymmetric design, this is the tread pattern:
The spare happens to be the same type but "original" (effectively Serie I) which has a very slightly different tread:
Work really well on my S8. :thumbs:
A20LEE
Post by A20LEE » Thu Nov 03, 2016 7:28 am
I've read that winter tyres should be changed at 4.5mm rather than 2mm like summer tyres. Most used ones for sale are around 4mm if you notice so basically they no good. Buy new
AdrianE
Post by AdrianE » Thu Nov 03, 2016 10:08 am
The 'legal' limit for winter tyres in those countries that require them is usually 4mm - for winter tyre use in typical UK conditions you can run them lower than that without problems and still benefit from the better cold weather performance. For proper snow performance I completely agree that the part worns won't be any use at all.
We run Dunlop Winter 3D with the AO (Audi) marking on a much smaller set of 18" rims (this is on our S5) but if you check the tyre pressure plate for the car it should give you a specific tyre size (usually marked as M&S) that's recommended - it's a lot easier running a spare set of rims and there's shed loads of German ebay sellers offering full sets with winter tyres. With the exchange rate they'll probably work out too expensive what with the time of year too.
There's a world of difference between a winter tyre and the specific requirements of driving on compacted snow. If you're likely to come across untreated roads you really need to pack some snow socks/chains for that extra bit of help if it's really icy. Accelerating isn't usually a problem but basic physics comes into play when braking so if there's no coefficient of friction between tyre and road surface, you won't be slowing down much....
Nokian usually get a good write up for their winter tyres - I tend to look at this lot for comparative prices:
Mytyres
Openeo
Camskill
Tyreleader.co.uk
Protyre
Pneusonline
Lovetyres.com
2011 S5 Sportback in Phantom Black with black leather, 9x20 7 spokes, tech pack high, phone prep high, adaptive xenon plus, intelligent key, memory seats pack, sunroof, B&O, Audi Drive Select & quattro Sports Diff, cruise, DAB, parking system plus, storage pack, through load
===SOLD=== 2002 S8 4.2 Final Edition in Avus Silver with mauve (purple!) leather, 8.5x20 9 spokes, bi-xenons, 10 way electric Recaros, added RNS-E, hybrid TV and bluetooth goodness - and a Milltek ===SOLD===
Puggie
Post by Puggie » Thu Nov 03, 2016 11:44 am
I've run significantly smaller Nokian WR-D3s on my Honda Insight and Integra Type-R in the past and they have been brilliant in the general winter grot. I'll be fitting them to the insight shortly and I find they are generally good once the weather is reliably below 7DegC for not only shifting snow and slush, but generally wet British weather. I did successfully pull a stuck Landy Disco off a verge about 4 years ago (last time we had snow) in my Integra Type-R on the above snow tyres, the difference in grip over a typical road tyre (and the R888s it usually ran) is quite astonishing. A friend runs the Hankook Icepts on his bimmer and rates them highly too.
I will be getting something for our RS6 C5 shortly and probably look at Nokians offerings first.
R33
Post by R33 » Thu Nov 03, 2016 4:28 pm
I went through a full set of the Pirelli's in one winter and in short I thought they were sh1t and on balance I'd have been better sticking to summer tyres (as we had no real snow 2 winters ago). Last year I bought the Dunlops and not only are they wearing much better but the cold weather grip appears significantly better to me in all aspects. You only have to look at the tread pattern to see that's probably going to be the case.
There may be better winters out there than the Dunlop's for our cars and as I haven't tried them I wouldn't know, but personally I wouldn't touch the Pirelli's with a barge pole.
lostandfound
Post by lostandfound » Thu Nov 03, 2016 10:03 pm
Thanks, I'm still waiting on prices, I'll post how I get on.
AdrianE
Post by AdrianE » Thu Nov 03, 2016 10:35 pm
Our Dunlops were part worn when we got them - done 2 winters to date, including half one summer due to a lack of supply of MPSS tyres. Going back on tomorrow for one more season
skirs6
Post by skirs6 » Wed Nov 09, 2016 6:14 pm
Second hand 6mm £300 ( thumbs up !!!! )
longman h
Post by longman h » Thu Nov 10, 2016 10:19 am
What colour finish are the wheels as they look awesome. Have you got more pictures with them on the car as I'm very tempted to have mine resprayed.
Daytona Grey C6 RS6 Avant
Ebony Black C5 RS6 Plus - Gone
stevo55
Post by stevo55 » Thu Nov 10, 2016 3:42 pm
How come you have an RS badge on your rear brake calliper? Mine are just black
Current:
Former:
2016 R8 V10 Plus.
2019 E63s AMG 4Matic Estate.
2017 BMW M3 Competition Pack.
2015 A45 AMG.Overrated POS.
2016 C7 RS6 Panther black.
2006 BMW Z4M Roadster.
2004 Alpina Roadster.
1994 E34 M5 Saloon
skirs6
Post by skirs6 » Fri Nov 11, 2016 8:12 pm
Colour is just Anthracite done by Wheel works Crawley. The RS plate is from the C7 you need to drill two 10mm holes then it's push fit.
SandyT
Post by SandyT » Sat Nov 26, 2016 8:46 pm
I just fitted a set of Toyo SnowProx S954's on my RS4. £165 a corner for 265/30/20 on the standard rims. Once they've bedded in I'll post some feedback.
HPsauce
Post by HPsauce » Sun Nov 27, 2016 12:28 pm
Puggie wrote:I've run significantly smaller
Good point, so do I. 20's in the summer, 18's in winter. :thumbs:
I find they are generally good once the weather is reliably below 7DegC for not only shifting snow and slush, but generally wet British weather..
Absolutely agree with that..
the difference in grip over a typical road tyre ..... is quite astonishing.
Indeed, the whole car is just so much more sure-footed as it gets colder and wetter/snowier. You forget just how much allowance you had to make for the loss of grip with "standard" tyres.
BUT, and it's a big but, remember that those around you most probably won't have the same abilities. :thumbsdown:
Once you get into the habit it's a no-brainer, winter tyres on when it gets cold (usually some time in Oct/Nov) summer tyres back on around April but timings aren't usually that critical.
My winters went on a bit early this year as I was doing some deals around my 20's and needed them off the car. But generally I adjust to work around the needs of tyre replacement and wheel refurbishment.
skirs6
Post by skirs6 » Sun Nov 27, 2016 8:54 pm
It's my first time on winters and I'm very happy. I went for 20's as I didn't want to buy new rims and I got a great deal from a forum member. On cold wet roads they are much better than summers.
Users browsing this forum: No registered users and 27 guests
