rs6 power gains?
5.0 V10 50v biturbo - 571 bhp
MiguelRocha
rs6 power gains?
Post by MiguelRocha » Fri Sep 02, 2016 9:19 pm
hi gyus, I need your help and your knowledge
what is the gain of power that is obtained with these specs? 750? 800? 850? injectores stock , High Pressure Fuel Pumps stock
-downpipes 3"
-no cats
-cat back miltek exhaust
-bmc filters
-forge BOV´S
-turbos TTE850
what is the maximum pressure that these turbos? with injectors and High Pressure Fuel Pumps stock?
live in Portugal, unfortunately it, I have not anyone with capacities to fine tune :thumbsdown: :thumbsdown:
anyone know who can tune my RS6, only the discretions I wrote.
of course sending my original file
regards
miguel rocha
rtd
rs6 power gains?
Post by rtd » Fri Sep 02, 2016 9:26 pm
Search post by lanh755 titled 900 spec should give you an idea of what is needed to go beyond 750 - 750 which is effectively known as stage 2 is attainable by just a remap anything beyond which is stage 3 will need hardware changes.
Volvo XC90
C7 - RS6
C6 - RS6
B5 - RS4
MiguelRocha
Re: rs6 power gains?
Post by MiguelRocha » Fri Sep 02, 2016 9:31 pm
I will search
thanks
IanH755
Post by IanH755 » Fri Sep 02, 2016 9:51 pm
Hi Miguel,
With the parts you listed you will make 820-830hp with the turbos at about 1.2 bar.
*however*
To run more power *safely* you need more fuel (loba HPFP or bigger injectors), more cooling (intercoolers, water/methanol) & the gearbox upgrading.
Hope that helps.
MiguelRocha
Post by MiguelRocha » Fri Sep 02, 2016 10:02 pm
hi Ianh755
yes helped ... thanks
my idea was the 800hp/820hp
now only needed someone to me tune to ECU
IanH755
Post by IanH755 » Fri Sep 02, 2016 11:28 pm
Mihnea from MRC often flies out to customers but that obviously costs more money, however he works in France so it might be worth getting your car transported to his French garage for the mapping.
MiguelRocha
Post by MiguelRocha » Sat Sep 03, 2016 6:04 pm
:biggrin3: good was coming to Portugal. :biggrin3:
skirs6
Post by skirs6 » Mon Sep 05, 2016 8:02 pm
I've read all the 750 plus threads but don't really see the point of going any higher I have 745 and can't even get close to using it.
To achieve this I only needed engine map, gear box map, filters decat pipes . To go any higher it's big money,and for what ???
IanH755
Post by IanH755 » Mon Sep 05, 2016 9:23 pm
[clarkson]POWWWWWWWER[/clarkson]
:D
TomRS
Post by TomRS » Tue Sep 06, 2016 3:50 pm
skirs6 wrote:I've read all the 750 plus threads but don't really see the point of going any higher I have 745 and can't even get close to using it.
I often use all of the power, i mean its a lot harder to really make use of it on the road, but i wouldnt say its "too much" on a track!
Audi RS4 B5 + Audi Q7 4.2TDi
Gone but not forgotten :smile_smoking:
2017 Mercedes E63S W213 1033/1400nm
2013 Mercedes E63S W212 740/1200nm
2010 Nissan GT-R SVM 680R
2010 RS6 C6 Avant Stage 2 730/1088nm
MiguelRocha
Post by MiguelRocha » Tue Sep 06, 2016 9:48 pm
:boohoo: :boohoo: :boohoo: :boohoo: :boohoo:
power is only for those who like.
who loves always wants more
:jump:
Users browsing this forum: No registered users and 39 guests
