Gear knob upgrade
5.0 V10 50v biturbo - 571 bhp
leet
Re: Gear knob upgrade
Post by leet » Sat Apr 30, 2016 1:09 pm
Looks great! Definitely something I'll be doing.
Audi-RS6-R
Post by Audi-RS6-R » Sat May 07, 2016 9:46 pm
Here's mine :beerchug:
TomRS
Post by TomRS » Tue May 17, 2016 3:48 pm
So how hard is this to do?
Audi RS4 B5 + Audi Q7 4.2TDi
Gone but not forgotten :smile_smoking:
2010 Nissan GT-R SVM 680R
Ungjaevel
Post by Ungjaevel » Tue May 17, 2016 3:52 pm
Read the guide, have to tools ready. 20-40 mins. You can do it.
TomRS
Post by TomRS » Tue May 17, 2016 4:11 pm
Ungjaevel wrote:Read the guide, have to tools ready. 20-40 mins. You can do it.
Am i being thick i cant find the guide?
Farravi
Post by Farravi » Sun May 29, 2016 6:02 pm
I can't either
Ceveman73
Post by Ceveman73 » Mon May 30, 2016 9:16 am
The procedure is called 'Heat & Twist' and is common among all Audi with the auto box.
Essentially, the procedure is lifting off the old gear knob to expose the plastic shaft that it sits on. Because the original shift button is on the side, and the new one is at the front, the plastic shaft is facing the wrong direction in relation to the new forward facing shift button. Fortunately the shaft is made of soft plastic and can easily be heated-up and twisted until it faces the right direction. Sounds scary, but is quite straightforward.
Full procedure guides here:
http://www.audizine.com/forum/showthrea ... -Knob-swap
http://forums.vwvortex.com/showthread.p ... nob-in-Mk4
The only advice is to go slow and take your time. Apply heat progressively and not too close, or you risk burning/melting the shaft.
Good luck :bigwave:
C6 RS6 Plus with a few sensible mods...
Jim Haseltine
Post by Jim Haseltine » Mon May 30, 2016 9:37 am
The metal clip that gets replaced with a zip tie in the first link can be replaced with a small CV joint boot clip, I fixed the gear knob in my daughter's boyfriend's Golf a few months back with a clip that was left over from another job.
Farravi
Post by Farravi » Tue May 31, 2016 10:49 am
Cheers Ceveman73, that was the missing jigsaw in the puzzle, really appreciate it.
Cheers Jum for the tip!
Duke Thrust
Post by Duke Thrust » Tue Oct 25, 2022 2:06 pm
Just to revive this...
Will any RS shifter from the same era fit? (specifically the gaiter)
Duke Thrust
Post by Duke Thrust » Mon Oct 31, 2022 12:29 pm
Answered my own question here. The shift knob and gaiter from a B8 RS4 fit perfectly, the aperture is exactly the same size. The only difference being the plastic trim that the leather gaiter is stapled to - the clips are in a different position. I carefully removed the staples and swapped them over and it's all done, an easy job to do.
(I preferred the gaiter from the RS4 as the stitching is light grey to match the stitching on my seats)
