Erratic engine oil DIS temperature reading
5.0 V10 50v biturbo - 571 bhp
mbelle
Post by mbelle » Mon Feb 15, 2016 7:59 pm
Good evening all...
Has anyone else experienced an issue whereby the engine oil temperature on the DIS will read erratically?
I've recently noticed within the last few days (having had my car recently returned from Audi after being with them for a month) that, from cold, it'll appear to accurately report the temperature, between --- and 99 degrees Celsius.
However, after reaching 100 (ish) degrees C, it will start to erratically read anything between 100-165 degrees!? :shock:
When I say erratically, I mean that, literally, within 3 seconds, it will jump between 100 --> 134 --> 149 --> 161 --> 124 --> 118, when driving normally. The numbers it jumps through are obviously quite random.
This can continue for minutes.
It'll then usually hold steady at 124, sometimes normalising to between 99-118 degrees C.
Fortunately, I've not had any warning or critical lights on the dash related to the engine.
I've also checked the dipstick and it's well within the Do Not Fill section.
Outside temperatures are between 4.5-9 degrees C.
Now, in my B5 RS4, 120 degrees was at the higher end of the temperature range for the engine oil; is that the case for this engine?
What is normal operating temperature for engine oil for this engine?
Could this simply be a faulty engine oil temperature sensor?
I've not got my Vagcom cable at present, so cannot check for codes. :(
Marcus
Current: A C6 Audi
Previous: A B5 Audi
Gumball0r
Re: Erratic engine oil DIS temperature reading
Post by Gumball0r » Mon Feb 15, 2016 8:24 pm
Had the same problem. The oil temperature sensor was changed - problem solved.
mbelle
Post by mbelle » Mon Feb 15, 2016 8:45 pm
Appreciated, thanks.
Do you happen to know where the sensor located?
Marcus
Current: A C6 Audi
Previous: A B5 Audi
Gumball0r
Post by Gumball0r » Mon Feb 15, 2016 8:55 pm
mbelle wrote:Appreciated, thanks.
Afraid not. My mechanic changed it.
mbelle
Post by mbelle » Tue Feb 16, 2016 4:44 pm
Will I be able to get an accurate reading of engine oil temperature via VAGCOM, or will this still rely on the sensors information?
I suspect that the sensor is faulty, but I don't want to be driving around with oil temp. as high as 150-165 degrees (at times) for too long, IF the oil is actually at that temperature...
Marcus
Current: A C6 Audi
Previous: A B5 Audi
rs6_sid
Post by rs6_sid » Tue Feb 16, 2016 6:32 pm
relies on the same information and i would say of experience of other vehicles it probably won't self diagnose the sensor as faulty, but i would say if its erratic it has to be sensor and not a hot engine as it should be a liniar heat up and cool down
c6 rs6 avant- mrc stage 2 -current
bmw e61 m5 saloon
s3 8p stage 2
vw bora tdi hybrid turbo
IanH755
Post by IanH755 » Tue Feb 16, 2016 8:34 pm
According to Elsawin the sensor is the G266 which is a combined Level and Temp sensor (two separate sensors in one housing) and the headlight & bumper have to come out to replace it - Pt No 420907660
mbelle
Post by mbelle » Thu Feb 18, 2016 11:06 am
Thanks all!
Marcus
Current: A C6 Audi
Previous: A B5 Audi
Users browsing this forum: hartley1967 and 64 guests
