Lights to LHD?
Re: Lights to LHD?
I have a LHD car, so have frequent visits to have this done when I head over. In my experience when my lights are set for the UK they are crap, as they are more centralised and low than when on the "Home" LHD setting. I can't tweak mine via MMI, which I can on my wifes Q5, didnt think it was an option via the MMI on these and mine was a 2010 build too.
Re: Lights to LHD?
All C6 RS6 have the old type BCM which where used in 2002 cars, the Q5 will have the new type to more options can be changed via VCDS and you will be able to add them onto the MMi.jezitalia wrote:I can't tweak mine via MMI, which I can on my wifes Q5, didnt think it was an option via the MMI on these and mine was a 2010 build too.
Trups
Re: Lights to LHD?
Apologies to revive this thread, but do tell...?Trups wrote:more options can be changed via VCDS and you will be able to add them onto the MMi.
Is it possible to add the switching of the lights from RHD/LHD and vice versa to the MMI menu using VCDS?
Marcus
Current: A C6 Audi
Previous: A B5 Audi
Current: A C6 Audi
Previous: A B5 Audi
Re: Lights to LHD?
you got 2g or 3g?
Trups
Trups
Re: Lights to LHD?
Marcus's (my old!) car has 2g - assuming it works similar to the system in a B7 then it's a piece of cake with VCDS
Current: Macan Turbo, Boxster 987 S
Gone: RS6 C6 Avant, RS4 B7 Avant, Tamora Speed Six
Re: Lights to LHD?
Thanks DALO.DALO wrote:Marcus's (my old!) car has 2g - assuming it works similar to the system in a B7 then it's a piece of cake with VCDS
I do have VAGCOM; I was just hoping that I could add it to the MMI menu to easily change it back when I return, rather than need to use the cable again.
I'll also be travelling over to the continent a few times next year, so it would be convenient to have it in the MMI menu.
Marcus
Current: A C6 Audi
Previous: A B5 Audi
Current: A C6 Audi
Previous: A B5 Audi
Re: Lights to LHD?
ah sorry... misread the question! have to leave that to someone more au fait with VCDS on the C6 I'm afraid - I knew it inside out on the B7 but sold the kit before I got the C6 so never go the chance to have a play
Users browsing this forum: No registered users and 198 guests
