There is no LC on c6 rs6's.adamgt wrote:It's the launch control I mean mate
Finally got one
- RossDagley
- Top Gear
Re: Finally got one
Previously:
Previously:
Re: Finally got one
If the RS6 had launch control(LC), I hope it would not be like the launch control on the other fine Audi product that I drive.RossDagley wrote:There is no LC on c6 rs6's.adamgt wrote:It's the launch control I mean mate
Every time I use LC on the LP560-4, I look in the rear view mirror to see that I have not left a trail of gearbox parts on the road behind me as the LC starts with the engine revving to 5000rpm and then when you take your foot of the brake, a loud bang is heard as all the slack is taken up in the transmission. True, the car does then run a 10.7 sec quarter mile, but I still cringe when use LC.
just my two cents worth,
cheers,
john
2009 RS6 sedan,5.0L FSI V10,phantom black,730bhp-98 octane,750bhp-104 octane,APR stage 1 map,MTM/Performance Friction 405mm front rotors,JCFabweld sports exhaust,MRC filters,Michelin PSS.
2011 Lamborghini Gallardo LP560-4 coupe,5.2L V10 TT UGR 800-1250whp, e-gear 6 speed,390 mm Alcon Racing front rotors, grey.
1969 E type Jaguar convertible with 5.2L 6 cylinder Rob Beere Racing engine,356 bhp-415 ft-lbs,midnight blue-old school but beautiful
- RossDagley
- Top Gear
Re: Finally got one
launch control is brutal on transmissions and engine mounts. Just ask the owner of the RS4 that lunched his car at santapod yesterday... I'd be the same - very frightened!
Previously:
Previously:
Re: Finally got one
Doug_S2 wrote:There is nothing special on our car and all the 720+and 1000nm cars should do this time - just esp fully off, in sport mode and brake, foot to the floor then let off the brake - it will be a 2000rpm launch with a bit of spool/lag - and that is where I think we can improve on that time.
Re: Finally got one
Its just the stall point on the torque converter.. I wouldn't hold it there for long or you'd damage the gearbox whereas launch control holds the revs on the throttle.
The ECU on the C5 won't let you do it, kills the power the moment it sees throttle at the same time as brake.
Re: Finally got one
Sounds good to me though mate
Re: Finally got one
A stock C5 ECU won't.SuprSi wrote:Its just the stall point on the torque converter.. I wouldn't hold it there for long or you'd damage the gearbox whereas launch control holds the revs on the throttle.
- Shinobi675
- 5th Gear
Re: Finally got one
How's it going Doug? Still loving it? Any new bits? How are you finding the handling with the springs and arbs?
Re: Finally got one
This is the first one i've driven other than just test drives so once you are over the size and get used to it- you can thrash it and it is a lot better on A roads than I expected. Just recalibrating to the braking distances took a while.
I've swapped it just now with the previous owner and a C7 RS6 for a few days so ill report back on his thoughts.
The Milltek non res exhaust, KW adjustable platforms, modded Intercoolers are going on when I get it back. 3" Downpipes after that, then Carbon Clean and deflap to see if we get a difference.
http://www.MRCtuning.com
Re: Finally got one
Carbon Clean....does the C6 suffer too?
RS6 C8 carbon black(merlin)
Panamera Turbo S e hybrid
RS6 C8 launch edition
R8 V10 plus
C7 RS6 PE dynamic pack plus
C7 RS6
Porsche Panamera Turbo
C6 RS6 AVANT
RS4 B7
Golf R32 mk 5
BMW M3 E46
Golf R32 mk 5
Golf GTI mk 5
VW Passat 130d 4 motion
VW bora 150pd
Ford Mondeo Ghia X V6
Ford Focus zetec
Rover 214!!
R8 V10 plus
C7 RS6
C6 RS6 AVANT
RS4 B7
Golf R32 mk 5
BMW M3 E46
Golf R32 mk 5
Golf GTI mk 5
VW bora 150pd
Ford Focus zetec
Rover 214!!
Re: Finally got one
yes all fsi do - turbos or forced charged don't tend to drop power anywhere as much as a na car - but still doesn't help.
Re: Finally got one
Heya, remembered you posted the 0-60 shot.Doug_S2 wrote:First shot at some 0-60 and 0-100 times. Esp fully off as front wheels spin in 1st. Laggy coming on boost in 1st so we will try some tweaks to get better launches.
Have you done 60-120 and have those times as well?
f
- RossDagley
- Top Gear
Re: Finally got one
I have a 30-130 time of 9.2 seconds if that helps give you an indication of the mid-range pull?Ungjaevel wrote:Heya, remembered you posted the 0-60 shot.Doug_S2 wrote:First shot at some 0-60 and 0-100 times. Esp fully off as front wheels spin in 1st. Laggy coming on boost in 1st so we will try some tweaks to get better launches.
f
Previously:
Previously:
Re: Finally got one
should have exhaust net week so back onto testing it more
think this was the best 100-200
- RossDagley
- Top Gear
Re: Finally got one
Need to work on your 30-130 there DougDoug_S2 wrote:should have exhaust net week so back onto testing it more
<snigger>
Previously:
Previously:
Users browsing this forum: Ooonst and 43 guests
