Hi all any one can help me my original cut off valve (blow off) is broken because of the high pressure air that comes from the boost so where can I find heavy duty cut off valve so It can take the high pressure
(That cut off valve is comes under the intake left and right side )
Audi RS6 2009 C6
Cut off
Re: Cut off
I'm no expert on the C6 RS but genuine Audi blow off valves are usually more than adequate and generally more reliable than aftermarket options. If it was mine, I'd be buying new oem parts
Re: Cut off
The blow off valves cannot be changed on their own, they are part of the air filter boxes. I'm running 9XX ps and have no issues with stock oem ones running 1.4 bar of boost.
Re: Cut off
It's function is to cut/blow off pressure >X bar/psi. It's not broken because of that. Perhaps due to particles in the system?9kade wrote:my original cut off valve (blow off) is broken because of the high pressure air that comes from the boost
Re: Cut off
Did you fix it? If so what was the problem?
Users browsing this forum: Google [Bot] and 80 guests
