TPMS Fault
5.0 V10 50v biturbo - 571 bhp
chriscollie
TPMS Fault
Post by chriscollie » Mon Jan 13, 2014 7:09 pm
Folks, the TPMS alarm goes off after a few miles of driving. Ive checked tyre pressures and all ok.
Anything else to check? Do these tend to have faults with them as I know these systems can be tempremental.
Thoughts and suggestions appreciated.
classba
Re: TPMS Fault
Post by classba » Mon Jan 13, 2014 8:10 pm
chriscollie wrote:Folks, the TPMS alarm goes off after a few miles of driving. Ive checked tyre pressures and all ok.
Reset it from the MMI and if it does it again then for sure the TPMS units at fault.
andy
Re: TPMS Fault
Post by andy » Mon Jan 13, 2014 8:12 pm
Mine did this a little while back now so I reset them from the MMI as suggested by classba and it's worked fine ever since :beerchug:
C6 RS6 Avant in Mugello Blue - sold :(
BMW M2 LCi
RS6chris!
Re: TPMS Fault
Post by RS6chris! » Mon Jan 13, 2014 8:15 pm
Same here
I think as they get older they do play up a little!
Re set, check pressures and all is well.
I sometimes go across a bumpy farm track, everytime it's set the TPMS off showing low pressure, when checked tyres are ok?
Must be something g to do with air in tyre getting"squashed" and sending sensor haywire!!!
Chris
RS6 C8 carbon black(merlin)
Panamera Turbo S e hybrid
RS6 C8 launch edition
R8 V10 plus
C7 RS6 PE dynamic pack plus
C7 RS6
Porsche Panamera Turbo
C6 RS6 AVANT
RS4 B7
Golf R32 mk 5
BMW M3 E46
Golf R32 mk 5
Golf GTI mk 5
VW Passat 130d 4 motion
VW bora 150pd
Ford Mondeo Ghia X V6
Ford Focus zetec
Rover 214!!
doodlebug
Re: TPMS Fault
Post by doodlebug » Mon Jan 13, 2014 8:19 pm
Batteries run out eventually and you have to replace.
classba
Re: TPMS Fault
Post by classba » Mon Jan 13, 2014 11:27 pm
The average life span of the TPMS batteries is seven years if I've remembered correctly.
Before resetting the TPMS from the MMI, make sure you have all the tyres pumped up to the correct value. I've found that the MMI shows between 1-2 PSI less from what the actual tyre pressure value really is so make sure that you clear the old value and lock in the new.
Bladerider
Re: TPMS Fault
Post by Bladerider » Tue Jan 14, 2014 12:46 am
Is there a way to check individual TPMS sensors in wheels ??
So if I had a set of four and the tyres were pumped up correctly but the alarm went off, proving there was a likely sensor error, how would I establish whether it was one or more and which were at fault ?
I have two sets of RS4 wheels now as well as some spare sensors so I am hoping I can make a full set and maybe even have a spare TPMS sensor that all definitely work.
I have tried a search but it tends to bring loads of "My TPMS has gone off, what should I do" type threads up.
Cheers.
J.
