Auto dim rear view mirror glass
Please read the "RS246 Group Buy Policy" in this forum before use.
Re: Auto dim rear view mirror glass
Post by Shoppinit » Wed Jul 15, 2020 3:52 pm
Mine's arrived, too. Annoyingly when I took the M3 out for a drive yesterday I noticed the mirror in that is borked.
You do them for E46 M3s, Mirrorjohn?
dch1n
Post by dch1n » Wed Jul 15, 2020 4:38 pm
Thanks for getting this sorted out Chris and thanks for the quick turnaround John, great service.
Just switched mine over (sorry, no pictures but I used the previous ones Chris posted for an idea of how it was out together). I used a plastic pick and a card (random loyalty card) to pry the housing open. Started at the top as it was the longest side and worked carefully around the corners to the bottom undoing the clips holding it together.
I'd had to be careful of the sensor at the bottom frontside, there's a small catch on the inside to pull outwards first to let the sensor slide out freely with the circuit/ mirror (I actually popped mine out with force which I wouldn't advise).
The mirror's attached by an adhesive foam pad, so you will need to pull that off with a bit of force but keep in mind that there's a wire connected to the back, so just work it slowly until you get access to remove the connector, remove it, then take the rest off.
You'll need some adhesive to attach the new mirror to the old circuit (and housing). The original is foam pad is about 2-3mm thick. I had some old unused pads which were for the licence plate, so just used that along side the old foam.
You'll also need to solder the circuit to mirror.
Clip sensor back in, put mirror into housing, firmly clamp housing together (caution to the soldered connections) and Roberts your father's brother.
Sent from my Pixel 2 using Tapatalk
ChrisA
Post by ChrisA » Wed Jul 15, 2020 4:53 pm
How too done guys. Hope it helps. 👍
viewtopic.php?f=9&t=134849
MirrorJohn
Post by MirrorJohn » Wed Jul 15, 2020 8:42 pm
Spot on Chris. Thanks for that
MirrorJohn
Post by MirrorJohn » Wed Jul 15, 2020 8:43 pm
Yes I sell the glass for the M3 mirrors as well
Human Joist
Post by Human Joist » Sat Jul 18, 2020 8:25 pm
Arrived and fitted. Cheers mate.
MirrorJohn
Post by MirrorJohn » Sun Jul 19, 2020 5:45 pm
Great news. Glad that it arrived and you got it fitted so quickly.
Kind Regards
John
steve2003rs6
Post by steve2003rs6 » Mon Aug 30, 2021 7:38 pm
Just had 2 r v mirrors upgraded by MirrorJohn.
He also fitted the new glass to the casings for me.
Superb job done and a really quick service.
Nice to know that I won’t have any corrosive liquid potentially damaging the interior because of failure.
Thank you John
MirrorJohn
Post by MirrorJohn » Mon Aug 30, 2021 7:51 pm
Thank you John
Thanks a lot for the kind words Steve
steve2003rs6
Post by steve2003rs6 » Mon Aug 30, 2021 9:05 pm
Hi John. I also put info in the c5 section.
Once again many thanks for your expertise.
steve2003rs6
Post by steve2003rs6 » Wed Dec 14, 2022 10:30 am
If anyone is interested I have a spare rear view mirror available with mirror johns glass upgrade already installed
Pm me for further info.
Now sold.
Return to “Group Buys”
Users browsing this forum: No registered users and 70 guests
