Cam Adjustment intermitent and battery Voltage
Posted: Sun Jan 25, 2009 3:49 am
Hello
I ´ve been logging this error for some time.
Used to clear to solve for a long time
Now everyday I get this.
Tested the cam adjustmente and after 2000 it turns ON as expected.
But riding hard the car in high rpm, most of the time cam adjst is OFF.
Besides, logging Voltage , I can see values from 13.7V to 11.9 V.
Anyone has logged Voltage and there´s all this range in the normal operation or it should be steady at 13.7 V ?
A faulty ground could generate all this ?
The last...is it "normal" change the cam adjst sensor in a 40000 miles car ?
Thanks !
Monday, 19 January 2009, 16:23:03
VAG-COM Version: Release 409.1-S
Control Module Part Number: 8D0 907 551 D
Component and/or Version: 2.7l V6/5VT G 0002
Software Coding: 05611
Work Shop Code: WSC 00227
1 Fault Found:
17927 - Camshaft Adjustment: Bank 1: Malfunction
P1519 - 35-10 - - - Intermittent
Thursday, 22 January 2009, 20:27:21
2 Faults Found:
17930 - Camshaft Adjustment: Bank 2: Malfunction
P1522 - 35-10 - - - Intermittent
Thanks !
1 Fault Found:
2 Faults Found:
