vagcom
Posted: Wed Sep 26, 2007 7:57 am
by irbell
hi lads,thinking of getting a vagcom from rosstech ,which software would you recommend for maf readings and fault codes as this is what i'll be using it for , and how easy are they to use ,because i'm a bit of a dinasaur on a computer .ta belly
RE: vagcom
Posted: Wed Sep 26, 2007 8:08 am
by AdamS4
You want this.... http://www.ross-tech.com/Merchant2/merc ... ode=VAGCOM
Use the VagCom software that you can download from Ross Tech
Posted: Wed Sep 26, 2007 1:23 pm
by irbell
hi ,i've got an interface from frebay and i'm just downloading version 409 to try it as i don't know which type of interface it is other than usb to obd ii,have set it up, but not reading interface when testing ,any ideas ,cheers belly
Posted: Wed Sep 26, 2007 1:29 pm
by Dippy
Is it connected to the car?
Posted: Wed Sep 26, 2007 1:57 pm
by irbell
hi dippy ,no i haven't got the car with me at the moment ,i'm just on the programs page on test but it just keeps searching,i'm doing this first as a cheapy, but will go for the full version soon ta belly,
Posted: Wed Sep 26, 2007 1:59 pm
by Blue_Thunder
You need to download the USB drivers. Can't remember what they are called now, but you need to search for something like "serial to usb drivers".
Posted: Wed Oct 03, 2007 12:58 am
by Sebastian
VAG-COM comes with (real) USB drivers for the genuine Ross-Tech interfaces, but if you are using a 3rd party interface your have to (as Blue Thunder already described) find the appropriate drivers yourself. Usually they come with your 3rd party hardware or the seller gives you a download location, if in doubt just contact the seller - he should know.
