Pulled my DTC's
si_hill
Pulled my DTC's
Post by si_hill » Sun Sep 17, 2006 9:42 am
Well finally got round to hooking the car up to VAG-COM yesterday and pulled the DTC's. Perhaps Doug or Minhea could confirm that the charge pressure fault is nothing to be worried about.
Saturday,16,September,2006,11:56:18
VAG-COM Version: Release 607.3-UD
Chassis Type: 8D - Audi A4 B5
Scan: 01 02 03 08 15 16 17 25 35 37 45 55 56 57 67 75 76 77
Address 01: Engine
Part No: 8D0 907 551 C
Component: 2.7l V6/5VT 03 0002
Coding: 05611
Shop #: WSC 00046
1 Fault Found:
17963 - Charge Pressure: Maximum Limit Exceeded
P1555 - 35-10 - - - Intermittent
Readiness: 0000 0000
Address 35: Centr. Locks
Part No: 8L0 862 257 G
Component: ZV-Pumpe, DWA, Funk D08
Coding: 15208
Shop #: WSC 06325
3 Faults Found:
01367 - Central Locking Pump Run Time Exceeded (Likely Leak)
35-00 - -
01370 - Alarm triggered by Interior Monitoring
35-00 - -
00957 - Key 3
09-00 - Adaptation Limit Surpassed
Will look into doing some logging next. The acceleration module looks like fun. Will be trying that out when I get a chance. :lol:
Does anyone know if there is a PDA version of VAG-COM?
dummi
RE: Pulled my DTC
Post by dummi » Sun Sep 17, 2006 10:33 am
good point that would be nice to be able to hook up a PDA
Jez
RE: Pulled my DTC
Post by Jez » Sun Sep 17, 2006 10:43 am
I don't think VAG-COM is compatible with mobile versions of windows yet, but would be great if it was :)
KayGee
RE: Pulled my DTC
Post by KayGee » Sun Sep 17, 2006 10:44 am
The last three are quite common and mine has always done them. The alram went off usually when car is left with someone in it. Key 3 adaption is usually caused because key fob battery is running low. Central Locking Pump run time is also common. Mine does it every now and again. Doors lock and unlock OK so never bothered with it.
First one is generally caused by a boost leak or a re-map that causes throttle cut.
CliveH
Re: RE: Pulled my DTC
Post by CliveH » Sun Sep 17, 2006 10:59 am
KayGee wrote: First one is generally caused by a boost leak or a re-map that causes throttle cut.
or a faulty N75 valve?
Clive
flashyg
RE: Re: RE: Pulled my DTC
Post by flashyg » Sun Sep 17, 2006 12:55 pm
I use a Fujitsu Siemens Stylistic PDA, perfect with vag com
Only error of issue is over-boost.
Logging will help,
fletchie55
Post by fletchie55 » Sun Sep 17, 2006 8:26 pm
can anyone explain what "Central Locking Pump run time" is?
shineydave
Post by shineydave » Sun Sep 17, 2006 8:32 pm
the length of time the central locking pump has to run before creates enough vaccum to lock the doors, it's a common fault code, had it a few times on mine, just cancel it and don't worry
fletchie55
Post by fletchie55 » Sun Sep 17, 2006 9:05 pm
hmmm interesting, my car does seem to take ages to lock the doors, much longer than any other car I have had. Will cancelling the error code fix this or do I need new pump?
CliveH
Post by CliveH » Sun Sep 17, 2006 9:11 pm
Clearing the error code wont fix the problem, but it will tell you whether it's an intermittent or permanent problem - ie if it doesnt recur after you've cleared it, then it was a one-off.
Clive
shineydave
Post by shineydave » Sun Sep 17, 2006 9:51 pm
could be a damaged vac line, mine locks quite promptly, press the button and it's locked
Nige_RS4
Post by Nige_RS4 » Mon Sep 18, 2006 9:05 am
Max charge pressure could be bypass valves or MAF - clear the codes and see if it comes back!
https://www.speedcams.co.uk
B5 2.7t S4 - gone
B5 2.7t RS4 - gone
Ed 30 Golf DSG - gone
2018 Golf R 7.5
si_hill
Re: RE: Re: RE: Pulled my DTC
Post by si_hill » Mon Sep 18, 2006 11:18 am
Nige_RS4 wrote:Max charge pressure could be bypass valves or MAF - clear the codes and see if it comes back!
Cheers Nige. As the car is running K04's etc I wondered if this code was to be expected due to to the remap. I have a spare MAF which came with the car so could try that, by bypass valves due you mean diverter valves? If so then these are AMD Turbo Technics items although they probably are about 3 years old. Can these be serviced?
I will sort out some logging to check the MAF etc. What are the best things to log apart from Mass Air Flow?
Nige_RS4
RE: Re: RE: Re: RE: Pulled my DTC
Post by Nige_RS4 » Mon Sep 18, 2006 12:40 pm
If you log block 115 you will see both requested & actual boost values - you should be OK as long as your not running more than 1.5bar peak max. I would suggest you AMD valves need servicing if they haven't been touched for 3 years. Diverter vales = bypass valves = BPV = dump valves (which in the case of the S4/RS4 is technically incorrect).
HTH
B5 2.7t S4 - gone
B5 2.7t RS4 - gone
2018 Golf R 7.5
Dr-Al
Post by Dr-Al » Mon Sep 18, 2006 12:52 pm
Jez wrote:I don't think VAG-COM is compatible with mobile versions of windows yet, but would be great if it was :)
Then we will need a Blutooth dongle...
Wrecked on 9 Oct 2007: 1998 Cactus Green S4, 710N DVs, Boost gauge (in custom A-pillar/dash mounting pod), cruise control retro-fit, Parrot 3200 Colour Hands Free, RS246.com sticker
Return to “DTC / VCDS”
