To VAG-Com users, FATS times database for the Euro S4s
Posted: Tue Jul 19, 2005 10:39 pm
Hi all,
I just thought that we should keep an FATS database for euro S4s so we can compare performance on things comparable. The reason for this is that the american S4 gearbox is totally different and the gear ratios are not the same as ours, so when we look at "their" FATS times, we can't really compare them with ours, as some baseline parameters are off for this comparison.
Ok, I'll start this, best FATS run done yesterday on my S4, it was 28 degrees C outside, there was only me in the car, lots of stuff in the trunk and in the backseat, half a tank of fuel, my FATS time was 4.57 seconds.
The mods are:
DarIntake kit with BMC dual cone filter setup
QST RS4 dual cat-back exhaust with no resonator (deleted by me)
Stock downpipes with gutted precats and 2 3" pipes in place of the stock main cats
Otherwise totally standard engine, 89k miles, 1998 S4 saloon.
Custom mapped ECU, not very elaborate though, as I never have enough time to get someone to drive my car so I can map it... and VAG-Com'd (same as lemmiwinks) to run 6 degrees on top of what I had programmed when I did it with the cats on.
Here is the block 003 log for the record, BTW, I'm pretty happy with the really high advance I'm running in the midrange, before I had my cats removed there was no way I could run so much advance. Fuel is Total 98 RON from Belgium.
Group A: '003
Engine speed Mass air flow Throttle angle Ign timing
TIME g/s 0-5deg=closed deg
STAMP /min g/s % ーBTDC
12,68 3080 35,89 14,5 31,5
12,97 3120 33,42 12,9 24
13,29 3120 30,53 12,5 23,3
13,58 3120 28,06 11,8 43,5
13,88 3160 25,75 11,8 42,8
14,18 3160 32,14 14,5 41,3
14,48 3280 99,31 100 27
14,78 3360 129,11 100 24
15,09 3520 167,39 100 17,3
15,39 3680 194,25 100 18
15,69 3880 195,06 100 18
15,99 4040 206,42 100 18,8
16,3 4280 215,42 100 18,8
16,63 4440 234,06 100 16,5
16,94 4680 238,53 100 14,3
17,27 4840 240,08 100 15
17,6 5040 239,64 100 16,5
17,94 5240 244,58 100 15
18,29 5400 247,06 100 17,3
18,64 5640 249,86 100 17,3
19 5760 256,81 100 17,3
19,36 5960 251,22 100 17,3
19,73 6080 255,5 100 20,3
20,1 6280 254,25 100 21
20,48 6440 252,69 100 22,5
20,86 6520 256,92 100 21
21,23 6640 254,78 100 21
21,61 6840 258,33 100 24,8
21,99 6920 253,42 100 21,8
My request is for all those who have VAG-Com, please post here your FATS runs (i.e. 3rd gear WOT and start logging from 3000 RPM to redline and check the time from 4200 to 6500).
Here is a FATS calculator where you input the times from VAG-Com or ECU Explorer http://ctny.audiworld.com/mark/s4/ecux/ ... s_time.xls, it is basically very useful for interpolating the exact time at 4200 and 6500 RPM if your VAG-com's resolution is as low as everybody else's and doesn't "catch" those RPM points exactly.
Here is also a FATS to HP calculator, seems pretty close to my estimations (I used 3770lbs for my car in this run, it comes up with 354 crank HP, I did come up with 350 HP based on the MAF output. http://www.vastperformance.com/faq.html
Now get your Vag-Coms, find a straight and flat stretch of road and do this please, it's for the benefit of the whole community!!!
Cheers,
Mihnea
The mods are:
Group A: '003
Cheers,
Mihnea
