Hello,
So my CEL has illuminated and the subsequent scan turned up the following:
Friday,11,September,2015,00:19:30:57902
VCDS -- Windows Based VAG/VAS Emulator
VCDS Version: 12.12.2.0
Data version: 20140212
VIN: WUARU78E87N904747 License Plate: 89TO44
Mileage: 189570km-117793mi Repair Order:
Chassis Type: 8E (8E - Audi A4/S4/RS4 B6/B7 (2001 > 2008))
Scan: 01 02 03 08 09 0F 11 15 16 17 18 25 36 37 45 46 55 56 57 65
67 69 75 76 77
VIN: WUARU78E87N904747 Mileage: 189570km/117793miles
Address 01: Engine Labels: 079-910-560-BNS1.lbl
Part No SW: 8E1 910 560 A HW: 8E1 907 560
Component: 4.2L V8/4V FSI TM0060
Revision: 57H13--- Serial number: XXXXXXXXXXXXXX
Coding: 01040009180F0160
Shop #: WSC 03122 444 58724
VCID: 244DF9E8E739D13EDFF-8071
1 Fault Found:
006435 - Please Check DTC Memory of ECU Number 2
P1923 - 008 -
Freeze Frame:
Fault Status: 01101000
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 189570 km
Time Indication: 0
Freeze Frame:
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Temperature: 89.0∞C
Temperature: 68.0∞C
Absolute Pres.: 990.0 mbar
Readiness: 0000 0000
Voltage: 11.557 V
Address 03: ABS Brakes
Part No SW: 8E0 910 517 G
Component: ESP8 quattro
Revision: 00000000 Serial number: 00000000000000
Coding: 0004533
Shop #: WSC 06335 000 00000
VCID: 2B5F12D48AE71E461E5-807E
No fault code found.
Address 08: Auto HVAC Labels: 8E0-820-043.lbl
Part No: 8E0 820 043 BM
Component: A4 Klimaautomat 3233
Coding: 00000
Shop #: WSC 00000
VCID: 6DDBDCCC2773D076401-5122
Address 09: Cent. Elect. Labels: 8E0-907-279-8EC.lbl
Part No: 8E0 907 279 N
Component: int. Lastmodul USA 0907
Coding: 01023
Shop #: WSC 65536
VCID: 3D7B2C8C379380F6B01-4AF8
Address 11: Engine II
3 Faults Found:
004897 - Knock Sensor 3 (G198)
Labels: 8E0-910-517.clb
HW: 8E0 614 517 BD
H06 0150
Labels: 079-910-560-BNS2.lbl
HW: 8E1 907 560
TM0060
P1321 - 002 - Signal too Small - Intermittent
Freeze Frame:
Fault Status: 00100010
Fault Priority: 0
Fault Frequency: 3
Reset counter: 255
Mileage: 189140 km
Time Indication: 0
Freeze Frame:
RPM: 2680 /min
Load: 50.2 %
Speed: 103.0 km/h
Temperature: 95.0∞C
Temperature: 34.0∞C
Voltage: 13.462 V
000768 - Random/Multiple Cylinder Misfire Detected P0300-001- -MILON
Freeze Frame:
Fault Status: 11100001
Fault Priority: 0
Fault Frequency: 2
Reset counter: 255
Mileage: 189348 km
Time Indication: 0
Freeze Frame:
RPM: 1338 /min
Load: 47.0 %
Speed: 0.0 km/h
Temperature: 23.0∞C
Temperature: 27.0∞C
Voltage: 12.827 V
000773 - Cylinder 5
P0305 - 001 - Misfire Detected - MIL ON
Freeze Frame:
Fault Priority: 0
Fault Frequency: 2
Reset counter: 255
Mileage: 189348 km
Time Indication: 0
Freeze Frame:
RPM: 1338 /min
Load: 47.0 %
Speed: 0.0 km/h
Temperature: 23.0∞C
Temperature: 27.0∞C
Voltage: 12.827 V
Address 15: Airbags Labels: 8E0-959-655-94.lbl
PartNoSW:8E0959655H HW:8E0959655H Component: Airbag 9.41 H12 3840
Revision: 91H12384 Serial number: 0036N0G0L6G5 Coding: 0432607
VCID: 3C7D21887F8989FE87F-8069
Subsystem 1 - Part No: 8E0 910 339 B
Component: BF-Gewichtsens. 002 0070
Subsystem 2 - Serial number: 3HM3B
Subsystem 3 - Serial number: 0001.01.000000200000000000ˇÜ63
Subsystem 4 - Serial number: 000000ˇÜ6332DRB404214529AˇÜ63
Subsystem 5 - Serial number: 14529AˇÜ6342DRB40424CC19SˇÜ63
Subsystem 6 - Serial number: 4CC19SˇÜ6352ARB401D57B68XˇÜ63
Subsystem 7 - Serial number: 57B68XˇÜ6362ARB401D40A93NˇÜ63
Subsystem 8 - Serial number: 40A93NˇÜ63729RB401D9A57D+ˇÜ63
Subsystem 9 - Serial number: 9A57D+ˇÜ63829RB401D9A5D4$ˇ
Subsystem 10 - Serial number: 9A5D4$ˇ
Address 16: Steering wheel
Part No: 8E0 953 549 T
Component: Lenks·ulenmodul
Coding: 04441
Shop #: WSC 06335
VCID: 448D59685479F13EFFF-4AF8
Labels: 8E0-953-549-T.lbl
0301
Address 17: Instruments Labels: 8E0-920-9xx-8EC.lbl
PartNoSW:8E0920982R HW:8E0920982R Component: KOMBI+WFS 4 H14 0100
Revision: 0100 Serial number: 00000000000000 Coding: 0023268
Shop #: WSC 12345 999 83976
VCID: 3D7B2C8C679380F6B01-5122
Address 25: Immobilizer Labels: 8E0-920-9xx-8EC.lbl
Address 36: Seat Mem. Drvr
Part No: 8E0 959 760
Component: Sitzmemory R2 F
Coding: 00002
Shop #: WSC 00000
VCID: F1E340BCBB4BB496E49-4AF8
Labels: 8E0-959-760.lbl
0305
Address 46: Central Conv.
Part No: 8E0 959 433 CG
Component: Komfortger·t T7B
Coding: 11880
Shop #: WSC 06335
VCID: 78F5FD98583165DEA37-4AF8
Labels: 8E0-959-433-MAX.lbl
4135
Subsystem 1 - Part No: 8E1959801G
Component: Tırsteuer.FS BRM 0706
Subsystem 2 - Part No: 8E1959802G
Component: Tırsteuer.BF BRM 0706
Subsystem 3 - Part No: 8E0959801E
Component: Tırsteuer.HL BRM 0606
Subsystem 4 - Part No: 8E0959802E
Component: Tırsteuer.HR BRM 0606
Address 55: Xenon Range Labels: 4F0-910-357.lbl
PartNoSW:4F0910357F HW:4F0907357F Component: AFS 1 H01 0020
Revision: 00000001 Serial number:
Coding: 0000019
VCID: 2953E8DC801B0C56EC9-807C
Subsystem 1 - Part No: 8E0 941 329 A
Component: AFS-Modul links H03 0020
Subsystem 2 - Part No: 8E0 941 329 A
Component: AFS-Modul rechtsH04 0020
Address 65: Tire Pressure Labels: 8E0-907-273.lbl
PartNoSW:8E0907273A HW:8E0907273A Component: Reifendruck 3 H04 0130
Coding: 0042725
Shop #: WSC 02197 785 00200
VCID: 2A5117D0861D074EE53-5122
1 Fault Found:
01521 - Sensor for Tire Pressure
004 - No Signal/Communication - MIL ON
Freeze Frame:
Fault Status: 11100100
Fault Priority: 3
Fault Frequency: 1
Reset counter: 40
Time Indication: 0
Freeze Frame:
(no units): 80.0
Voltage: 13.70 V
(no units): 61.0
Not Recogn.
Not Recogn.
Not Recogn.
Not Recogn.
Address 76: Park Assist Labels: 8E0-919-283-8EC.lbl
PartNoSW:8E0919283D HW:8E0919283D Component: Parkhilfe 4-Kan H06 0010
Revision: 00H06000 Serial number: 00067802030631 Coding: 0000304
VCID: 316300BCABCB7496249-5122
Address 77: Telephone Labels: 8P0-862-335.lbl
PartNoSW:8P0862335J HW:8P0862335J Component: FSE_255x BT H26 0290
Revision: 00000000 Serial number: 00000005013346 Coding: 0011877
End
Thoughts?
B7 RS4 004897 000768 000773 Misfire
Post by CaptainLF » Thu Sep 17, 2015 10:58 am
2007 B7 RS4 Daytona Grey, JHM Short Throw Shifter, Carbon Fibre Front Spoiler, OEM iPod Adapter, OEM Roof Racks and Ski Box, EUDM OEM RS4 Winter Rims with Nokian Hakkapeliitta R2 Tires, KW v3
Jump to
- General Discussion Forums
- ↳ Welcome Area
- ↳ General Car Chat
- ↳ Trackdays and Meets
- ↳ Spotters Forum
- ↳ Adversaries
- ↳ BMW M & Alpina
- ↳ Jaguar R
- ↳ Mercedes-AMG
- ↳ Nissan GT-R
- ↳ Opel VXR & HSV
- ↳ McLaren
- ↳ Porsche
- ↳ Volvo S60 Polestar
- ↳ Other
- ↳ Audi S and RS Ownership
- ↳ DTC / VCDS
- ↳ Electrical
- ↳ Cleaning & Car Care
- ↳ Readers' Rides
- ↳ Off Topic Chat
- ↳ Cars
- ↳ Parts
- ↳ Group Buys
- ↳ Other
- ↳ Ads Up To End Of 2010
- ↳ RS2 (B4) 1994-1995
- ↳ RS3 (8PA) 2011-2012
- ↳ RS3 (8VA) 2015-
- ↳ TTRS (Mk3 Typ 8S) 2014–
- ↳ RS4 (B5 Typ 8D) 1999-2001
- ↳ RS4 (B7 Typ 8E) 2006–2008
- ↳ RS4 (B8 Typ 8K) 2012-2016
- ↳ RS4 (B9 Typ 8W) 2017-
- ↳ RS5 (8T) 2010–2015
- ↳ RS5 (F5) 2016–
- ↳ RS6 (C7 Typ 4G) 2013-2018
- ↳ RS6 (C8 Typ 5G) 2019-
- ↳ RS7 (4G) 2013-2019
- ↳ RS7 (C8) 2019-
- ↳ RS Q3 (Typ 8U) 2013-
- ↳ RS e-tron GT (J1) 2020-
- Audi S Discussion Forums
- ↳ S Forums (Up to 1997)
- ↳ S1
- ↳ S2
- ↳ S4 2.2 / S4 4.2
- ↳ S6 / S6 Plus
- ↳ S1 (Typ 8X) 2014-
- ↳ S3 (Typ 8L) 1999-2003
- ↳ S3 (Typ 8P) 2006-2012
- ↳ S3 (Typ 8V) 2013-
- ↳ TTS (Typ 8J) 2008-2014
- ↳ TTS (Typ 8S) 2014-
- ↳ S4 (B5 Typ 8D) 1997-2002
- ↳ S4 (B8 Typ 8K) 2009-2016
- ↳ S4 (B9 Typ 9L) 2017-
- ↳ S5 (B9) 2017-
- ↳ S6 (C5 Typ 4B) 1999-2003
- ↳ S6 (C6 Typ 4F) 2006-2011
- ↳ S6 (C7 Typ 4G) 2012-2018
- ↳ S6 (C8) 2019-
- ↳ S7 (Typ 4G) 2012-2017
- ↳ S8 (D2 Typ 4D) 1992-2002
- ↳ S8 (D3 Typ 4E) 2002-2009
- ↳ S8 (D4 Typ 4H) 2010-
- ↳ SQ2 (MQB) 2019-
- ↳ SQ5 (Typ 8R) 2013-2017
- ↳ SQ5 (Typ FY) 2017-
- ↳ SQ7 (Typ 4M) 2016-
- ↳ SQ8 (MLB) 2019-
- ↳ Circuit Days
- ↳ Destination Nurburgring
- ↳ EM Tuning Products
Users browsing this forum: No registered users and 70 guests
