cheers for this Mike - mine has been giving me the red warning light on and off for the past couple of days, it's been driving me nuts as it beeps 3 times everytime it goes off and that can be every minute of so. just got the local garage to disable it for the time being.
Re: Turn off TPMS B7 RS4
Posted: Thu May 16, 2013 4:54 pm
by MikeFish
Had to turn mine off too as none of my local garages wanted to remove the tyres, fit the new sensors then replace the tyres. Gotta wait till I get new tyres.
Posted: Thu Jul 18, 2013 10:53 pm
by anissuba
MikeFish wrote:Had to turn mine off too as none of my local garages wanted to remove the tyres, fit the new sensors then replace the tyres. Gotta wait till I get new tyres.
Hi mike the rostech link you quoted is not showing any info on how to disable tpms. A friend of mine wants this doing. I have vagcom so dont mind doing it for him
Can you shine some light on it pls.
Posted: Thu Jul 18, 2013 11:21 pm
by Noyjatat
What has he done to try and solve the problem?
I has something similar and it was all down to a tyre pressure mismatch of 4 psi between the wheels. A quick check of the front pillar of what they should be and tyre pressures changed to match along with a wheel change entry on the computer and it solved my problem buddy.
Posted: Fri Jul 19, 2013 12:27 am
by anissuba
He told me that when purchased the car the old owner removed them when he the tyres were changed. Put new valves in without sensors ( must be a back street job)
You need to go into the Intrusment Cluster, select channel 061, make a note of the current value (just in case you mess anything up), then subtract 512 from it.
Cheers mike will give this a go.
Posted: Wed Jan 22, 2025 3:37 am
by frogracing
Reviving this old thread, I made a video showing how to do it here:
