Turn off TPMS B7 RS4
Diagnostic Trouble Codes (DTC) / VCDS (VAG-COM) forum
EuroSag
Post by EuroSag » Wed Mar 06, 2013 10:48 pm
Can the TPMS be disabled via Vag-Com?
And if so, where abouts is it to be found?
Cheers :)
Porsche 997 GT3 - 2010/60
Porsche 997 GT2FS - 2008/58
Peugeot 205 1.9 GTI-S - 1991/J
Audi B7 RS4 Saloon - 2007/07
Audi Q7 3.0TDI - 2011/11
Alfa 147 GTA - 2003/53
Ford F150 Raptor - 2012/62
Re: Turn off TPMS B7 RS4
Post by MikeFish » Wed Mar 06, 2013 11:08 pm
Yes it can. I think it's under instrument, can't remember the channel but I remember you subtract 512. I'll have a little google.
Post by MikeFish » Wed Mar 06, 2013 11:16 pm
toyneg
Post by toyneg » Thu May 16, 2013 3:53 pm
cheers for this Mike - mine has been giving me the red warning light on and off for the past couple of days, it's been driving me nuts as it beeps 3 times everytime it goes off and that can be every minute of so. just got the local garage to disable it for the time being. :bigwave:
Post by MikeFish » Thu May 16, 2013 4:54 pm
Had to turn mine off too as none of my local garages wanted to remove the tyres, fit the new sensors then replace the tyres. Gotta wait till I get new tyres.
anissuba
Post by anissuba » Thu Jul 18, 2013 10:53 pm
MikeFish wrote:Had to turn mine off too as none of my local garages wanted to remove the tyres, fit the new sensors then replace the tyres. Gotta wait till I get new tyres.
Hi mike the rostech link you quoted is not showing any info on how to disable tpms. A friend of mine wants this doing. I have vagcom so dont mind doing it for him
Can you shine some light on it pls.
B7 RS4
Noyjatat
Post by Noyjatat » Thu Jul 18, 2013 11:21 pm
What has he done to try and solve the problem?
I has something similar and it was all down to a tyre pressure mismatch of 4 psi between the wheels. A quick check of the front pillar of what they should be and tyre pressures changed to match along with a wheel change entry on the computer and it solved my problem buddy.
anissuba
Post by anissuba » Fri Jul 19, 2013 12:27 am
He told me that when purchased the car the old owner removed them when he the tyres were changed. Put new valves in without sensors ( must be a back street job)
B7 RS4
Post by MikeFish » Fri Jul 19, 2013 10:31 am
Looks like the link has changed since May.
Try Here:
http://wiki.ross-tech.com/wiki/index.ph ... C/8ED/8HE)
You need to go into the Intrusment Cluster, select channel 061, make a note of the current value (just in case you mess anything up), then subtract 512 from it.
anissuba
Post by anissuba » Fri Jul 19, 2013 11:39 am
MikeFish wrote:Looks like the link has changed since May.
Try Here:
Cheers mike will give this a go.
B7 RS4
frogracing
Post by frogracing » Wed Jan 22, 2025 3:37 am
Reviving this old thread, I made a video showing how to do it here:
Return to “DTC / VCDS”
