Pulled my DTC's
Diagnostic Trouble Codes (DTC) / VCDS (VAG-COM) forum
si_hill
Re: RE: Re: RE: Re: RE: Pulled my DTC
Post by si_hill » Mon Sep 18, 2006 1:28 pm
Nige_RS4 wrote:If you log block 115 you will see both requested & actual boost values - you should be OK as long as your not running more than 1.5bar peak max. I would suggest you AMD valves need servicing if they haven't been touched for 3 years. Diverter vales = bypass valves = BPV = dump valves (which in the case of the S4/RS4 is technically incorrect).
HTH
Cheers I will give that a go. I am not sure what max boost is reading as it goes off the gauge :roll: , will check what the gauge goes up to when i get home this evening. I will check with Mik to see if the bypass valves have ever been serviced. I know the car passed a healthcheck at MRC only a few weeks ago so I would have thought they would have picked up any issues then?
Mik
RE: Re: RE: Re: RE: Re: RE: Pulled my DTC
Post by Mik » Mon Sep 18, 2006 11:15 pm
Yep the bypass vavles have been serviced before, but perhaps not lately. Should say when exactly in some of the paperwork...
Read the boost with VAG.COM?
Mik
2014 Suzuka RS6
Mik
Post by Mik » Mon Oct 02, 2006 11:56 pm
What do you mean "you should be OK as long as your not running more than 1.5bar peak max" ?
Mik
HTH
2014 Suzuka RS6
Return to “DTC / VCDS”
Users browsing this forum: No registered users and 20 guests
